torque specs on upper and lower control arm bolts
Old Dec 29, 2000 | 07:16 PM
LightStruck's Avatar
Post torque specs on upper and lower control arm bolts
HELP:
Does anyone have access to shop manuals or other source of torque specs for the upper and lower control arm mounting bolts. Just saw something in another post that was WAY different from what local dealership service manager told me to tighten to.
Any help would be appreciated--(I don't want anything falling off--an occasional clunk is enough excitement for me.)
Old Dec 29, 2000 | 07:43 PM
Lightningquick's Avatar
Post
Crank her down boy!!!!!
1,350,250 ft lbs should stop her from clunking and nothing less!
I have seen dealers just go to it with a Air gun and go to town.
Old Dec 29, 2000 | 07:59 PM
Post
Actually I was serious, the dealership told me 55-60 ft-lb. This sounds pretty light for a 5/8" bolt that stories have mechanics with a 4 foot pull-bar pulling as hard as they can.
However, what's the tolerance on that 1,350,250??? Plus/minus 250 be aight?
Old Dec 29, 2000 | 08:27 PM
wilywilky's Avatar
Post
Hello to all:
Here are the numbers right out of the Ford Workshop Manual.
Torque Specifications
Description Nm Lb-Ft
Brake Hose Bracket to Front
Suspension Lower Arm Screw 13-17 10-13
Front Stabilizer Bar Bracket Bolt 26-35 19-26
Front Stabilizer Bar Link Nut 21-29 15-21
Front Suspension Lower Arm Nut 164-200 121-148
Front Suspension Upper Arm Cam
Bolts and Nuts 113-153 84-112
Front Suspension Upper Arm Nut 113-153 84-112
Lower Ball Joint Nut 113-153 83-112
Shock Absorber Lower Nuts 30-40 22-29
Tie Rod Castellated Nut 77-103 57-76
Upper Ball Joint Castellated Nut 77-103 57-76
Upper Shock Absorber Nut 47-63 35-46
I hope this posts properly.
Wilk
'97 F-150 4x4 Super Cab; XLT 139" Wheelbase Flairside; Silver Frost Clearcoat; 4.6L. (Romeo); 4-spd Automatic Transmission; Preferred Equipment Package 507A; 3.55 Limited Slip Axle; Electronic Shift 4x4; California Emissions; Sliding Rear Window; Trailer Towing Package; Off-Road Package; 6-Way Power Driver's Seat; Remote Keyless Entry/Anti Theft; 6-Disc CD Changer; Ford Bedliner; Ford Running Boards; Ford Nose Mask; Roll n Lock Tonneau Cover.
2000 SVT F-150 LIGHTNING XLT; 120" Wheelbase; Flareside; 5.4L EFI SOHC V8 SC Engine; 4-SPD Automatic; Silver Clearcoat Metallic; SVT Online Store Lightning Front End Mask; Roll n Lock Tonneau Cover.
Old Dec 30, 2000 | 09:34 AM
Post
Thanks wilywilky,
It looks like my super-helpful, full-of-information local dealership service dept. doesn't care if the front end falls off my truck or not.
They tell me 55-60 for all, and the book says 84-112 upper and 121-148 lower. Maybe I'll pay them another visit and explain how much I appreciate their help!
