Question for high HP 30" DOT slick users
Old May 7, 2007 | 01:43 PM
N8STRK's Avatar
I searched and didn't find much on this.
On a 600+ HP truck running 30" MH DOT slicks on 16" Bogarts do I need to secure the tires to the rims? Screws? Beadlocks? Tubes?
Any input would be appreciated.
Old May 7, 2007 | 01:59 PM
cobratruck's Avatar
I would use tubes. From what I have read, anything over a 29" needs tubes.
Old May 7, 2007 | 03:12 PM
Incogneto's Avatar
If you use tubes you MUST use screws. You don't have to use tubes and if you don't you can still screw them to the wheel as I did.
Old May 7, 2007 | 04:28 PM
Rob_00Lightning's Avatar
I would say at that power level YES you want them screwed, I have mixed opinions on tubes or no tubes, personally I prefer NO tubes but tubes will hold air a little longer in the event you puncture a tire (which I wouldnt want @ 140 MPH ; o()
Fast Freddy showed me how his slicks moved on his rims recently and I've seen others move at less power than your talking so in short the answer is
"SCREWED"
