fog light question
Old Dec 28, 2000 | 07:54 PM
redrocket's Avatar
Question fog light question
I want to run the fog lights when ever I want to. I have checked the FAQ and mine is a 99. I have already ground down the slot in the switch but no fog lights. What's next?? Help!
99.5 F-150 SVT Lightning (Red)
SuperChip R9
PSP Filter Kit
Mobil 1 Oil
Clear Corners
Straight Pipes
Window Tint
Snuglid
Chrome Lightning Wheels
Build Date 8-20-99
Build Number 3889 of 4000
1998 Honda ST1100
1998 Kawasaki Mojave 250
1998 Kawasaki Lakota 300
Old Dec 28, 2000 | 08:09 PM
videoman's Avatar
Cool
redrocket-
I did this about 9 months ago on my RED 1999. Actually very simple if you have a dremel tool. You have to grind down BOTH steps of the switch. You can see these by rotating the switch. It was eaiser by drilling 2 holes (one on each side of the switch) large enough tom get the dremel tool inside to grind down the 4 steps. Then test the fog lamp switch by pulling it up in different positions to make sure it work.
Connect a jumper wire from the black and white stripped wire from the auto headlights to the brown wire(with scotch-locks) fog lamps.
I believe this activates the fog light relay to activate the fog lamps.
The fog lights will work with the park lamps, headlights and auto lamps.
Mines been fine for 9 months and I run them with the park lamps when ever the my Lightning is running.
Hope this helps?
Have you wired your tail lights for 4 bulbs yet? Right now you only have 4 tail and 2 brake lights. Makes a world of difference when you brake.
Dan
99.5 Vermillian Red SVT Born on date:
8/24/99 # 2094
N.L.O.C # 461
TEAM PSP MODIFIED.
A.R.E II w/wing
Best Time:
12.77 @ 105.80mph (SO FAR)
1.80 60ft
8.15 @ 85.55 mph 1/8
Putting on the new PSP 3 psi Lower Blower Pulley this week!!For Testing.
WE BE SMILIN NOW!!
[This message has been edited by videoman (edited 12-28-2000).]
Old Dec 28, 2000 | 09:43 PM
redrocket's Avatar
Post
Thanks Videoman for responding.Let me make sure I understand. I need to connect the black and white stripped wire on the far right plug (there are two black and white wires) to the brown wire on the far left plug??
Old Dec 29, 2000 | 10:41 AM
redrocket's Avatar
Unhappy
BTT
SuperChip R9
PSP Filter Kit
Mobil 1 Oil
Clear Corners
Straight Pipes
Window Tint
Snuglid
Build Date 8-20-99
1998 Honda ST1100
Old Dec 29, 2000 | 03:13 PM
SVT_Wannabe's Avatar
Post
Red,
Doug has a how-to on this subject over at svtlightnings.com
It's well done and would probably answer your questions.
Old Dec 29, 2000 | 03:21 PM
redrocket's Avatar
Post
Thanks SVT, but mine's a 99. That mod is for the 2000. Come on, I know someone out there know the answer to my question.
SuperChip R9
PSP Filter Kit
Mobil 1 Oil
Clear Corners
Straight Pipes
Window Tint
Snuglid
Build Date 8-20-99
1998 Honda ST1100
redrocket's Avatar
Post
[QUOTE]Originally posted by redrocket:
[B]Thanks SVT, but mine's a 99. That mod is for the 2000. Come on, I know someone out there knows the answer to my question.
