problem with truck jumping forward when starting
Old Dec 26, 2000 | 06:59 PM
clonetek's Avatar
Question problem with truck jumping forward when starting
i remember someone talking about their truck "surging" forward when they crank it.
cant remember who it was, and searching has turned up nothing.
sometimes my truck jumps forward when i start it. its like it's taking the slack out of the driveline.
it rolls forward 6 inches or so and then right back.
it doesnt do it all the time, and i havent figured out a pattern yet.
does anyone else have this problem?
is there a fix?
Old Dec 26, 2000 | 07:24 PM
blue blood's Avatar
Lightbulb
The fix is simple...Parking Brake
Old Dec 26, 2000 | 07:42 PM
Lightningquick's Avatar
Post
Mine does it also once in a while.More so when its cold out.I wouldnt worry,Its a common thing on all cars once in a while.
Old Dec 26, 2000 | 10:22 PM
Twinturbo Ranger's Avatar
Unhappy
I've always owned standards,but in the autos I've owned I've never had this problem until I bought this Lightning. I'm not going to worry about since it's so intermittent. If it gets worse or something I'll think about it.
00 White Lightning,R9 Superchip,Homemade induction with cone type K&N filter,Magnaflow Muffler. 93 Ford Ranger,FI 302 with 185 AFR heads,GT-40 lower intake w/Downs upper,65 mm TB,66 lb injectors controlled by Western Motorsports SDS fuel injection,TDC Stage 2 twin turbos,AOD trans w/Lentch strip valvebody,10 inch convertor and single input shaft,8.8 rearend w/mosier 31 spline axles and 3.73 gears,and plenty more !!
Old Dec 26, 2000 | 10:32 PM
LightStruck's Avatar
Post
Maybe with 360 hp turning the fan, it's acting like a propeller! Then the transmission catches and holds her on the ground....
Old Dec 26, 2000 | 10:34 PM
Spiro99SVT's Avatar
Post
Mine does it also. Like Ray said, it seems to do it more often when the truck is really cold, or has been sitting for some time.
Spiro-
Old Dec 26, 2000 | 11:01 PM
clonetek's Avatar
Talking
okay.. mine usually does it if it has been sitting for a while, or if its really really cold.
*note to self* dont park too close behind anyone.
is that the fix?
Old Dec 27, 2000 | 01:03 AM
HANKFAN's Avatar
Post
Maybe it's just all that torque!!!
HANKFAN
Old Dec 27, 2000 | 01:08 AM
LTNBOLT's Avatar
Cool
Since it's been colder mine's doing it too. It only moves about an inch or 2.
Later,
Chuck
Black 00
Chuck's Lightning Page
Old Dec 27, 2000 | 09:48 AM
LightningKid's Avatar
Post
Clonetek, try this....
L2 moves forward when i start it? - F-150 Online Message Board
Address: https://www.f150online.com/f150board...ML/006182.html
This was posted 9-25-00.
You my also try searching by user name Factory_Tech as he has talked about this before (His expertise)
Mine also did it when it was cold also, but I figured it was a torque convertor lock-up thing, no big deal.
My new '01 pick-up does it also...
Old Dec 27, 2000 | 01:13 PM
clonetek's Avatar
Post
hmm... i hope it doesnt get any worse.
Old Dec 27, 2000 | 01:32 PM
RTKILLA's Avatar
Post
I better not start mine up anymore when I just got the front jacked up!!!!!!
