Warranty and Suspension Mods
Old Dec 20, 2000 | 09:51 PM
SVT2143's Avatar
Post Warranty and Suspension Mods
I'd like to know how modifying my suspension will affect the warranty. I plan to lower my L 2 inches all the way around. I'm sure as "L" not gonna do it if doing so voids the warranty.
Old Dec 21, 2000 | 12:25 AM
DreaminAboutL's Avatar
Post
Well, the warranty on your suspension will be void... spring problems, shackle problems, leaking shocks... all that is on your nickel. Probably wont cover alignment problems, weird tire wear, bearing problems, etc.
The warranty on the rest of the L will be fine, i.e. if your A/C stops working, that's still under warrentee, I/C leaks covered, etc.
Warranty wise, a chip could get you into a lot more trouble than just a 2" drop...
Old Dec 21, 2000 | 01:48 AM
Burninout101's Avatar
Post
Well, They could say beings you lowered the truck from the factory setting, inturn changed the angle of the driveshaft, so if you have any rearend or tranny problems they can relate to the drive shaft, you may be in for a treat in going round and round with them proveing the angle was not lowered. Just a thought
Old Dec 21, 2000 | 08:51 AM
LightStruck's Avatar
Post
Just save yourself some time/trouble/money and DON'T bother with control arms. Just get the springs.
Old Dec 21, 2000 | 04:37 PM
SVT2143's Avatar
Post
Can anyone tell me what the cost is (roughly) for parts 2" drop coils, camber adjustmant kit and installation?
Old Dec 21, 2000 | 04:38 PM
SVT2143's Avatar
Post
Can anyone tell me what the cost is (roughly) for parts 2" drop coils, camber adjustment kit and installation?
SVT2143's Avatar
Post
Can anyone tell me what the cost is (roughly) for parts 2" drop coils, camber adjustment kit and installation? I can spell
Old Dec 21, 2000 | 04:51 PM
Post
Front coils: 100-150$
adjustment kit cam/bolts: 60-100$
install: ??? (DIY! Not too bad, if you're into mechanic-ing.)
Alignment: 39-150$--probably according to where you go/how close you want it/how much time they spend.
Rear shackles: 40-75$ Easy to do as well.
[This message has been edited by LightStruck (edited 12-21-2000).]
