Help!!!!
Old Dec 17, 2000 | 05:35 PM
99SVTBoy's Avatar
Unhappy Help!!!!
I just bought a 99 Lightning has 11,000 miles on it. After i am done driving it around it smells like i have a coolant leak , but i cant seem to find where it is coming from ther are no leaks to be seen just the smell . I started it up and opend the hood and the smell seems stronger on the passenger side of the compartment. Any ideas guys i would also like to know what the k&n filter # is to replace the stock air filter, went to auto zone and they didnt know their book only went to 98.
Old Dec 17, 2000 | 05:56 PM
99SVTBoy's Avatar
Post
I checked thr level of the ic coolant and it seems fine . My mian coolant tank on the driver side was a little low though.
Old Dec 17, 2000 | 06:22 PM
A-Lightning's Avatar
Unhappy
Strictly a guess!!
Check the hose clamp for the heater hose on passenger side right above #4 coil pack.
Check it to be sure it's tight!
99.5 White Lightning
PSP chip
PSP Filter kit
13.29@102.55
Old Dec 18, 2000 | 02:59 PM
99SVTBoy's Avatar
Cool
A -Lightning u were right on the money it was the clamp. Thanks a million.
Old Dec 18, 2000 | 03:21 PM
Silver_2000's Avatar
Post
Dont waste $50 on the replacement KN filter - It is the air box that is the restriction. About 6 months ago a compare was done between the Stock filter and stock type K&N and no HP difference was seen. Get one of the after market filter kits -- Much better use of your money..
Doug
[This message has been edited by Silver_2000_! (edited 12-18-2000).]
Old Dec 18, 2000 | 05:36 PM
Don C's Avatar
Post
99SVTBoy
Welcome to the message Board
Aint this site great, you find a problem and we fix it.
I love it
Don
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bullet Cat Back, Superchip, K&N FIPK Intake.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Alpine CDA-7845, ADS P640 Amp, Focal Poly Kevlar seperates.
SILVER 2001 LIGHTNING on order
http://members.tripod.com/donf150/Welcome/id7.html
Old Dec 18, 2000 | 06:01 PM
SCOTTODOG's Avatar
Post
If your truck seems to be running a little rough it may be the right rear coil bad from the anti-freeze leaking from that clamp onto the coil. I had mine replaced from the leaking clamp at about 11,000 also.
Old Dec 18, 2000 | 06:06 PM
TampaBayLightning's Avatar
Post
Boy:
The part # for the K & N is 33-2140.
Personally, I like and retained the stock box. It's an owner's choice.
Congrats!
Rich
1999.5 SVT Lightning - Red. 100HP Shot NOS, BellTech 3/4 drop, Super Chip(TRAC). K&N Filter. Viper Alarm w/remote start, Sir Michael's roll pan, smooth corners and steps w/billet inserts, clear corner lenses, Cervinis Ram Air hood, ARE Cover w/ wing, Momo billet pedals, cd changer, cover, Phantom boost and nitrous gauges, MTX Thunderform w/ 2 10" MTX Thunder 4000 subs. 5-channel 500w. Clarion amp.(APA5241), (4)Polk Audio 3-way, 130w. DX 7's, Color-matched Muth signal mirrors, Soundproofed cab, BedRug, Trenz billet grills, Piaa 9007 Super Whites, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt/
2001 PT Cruiser - Limited Edition
1999.5 Expedition XLT
Old Dec 18, 2000 | 10:00 PM
99SVTBoy's Avatar
Post
It is running a little rough. When idling at stops I realy notice it, so i am taking it to the dealer wed.
[This message has been edited by 99SVTBoy (edited 12-18-2000).]
Old Dec 19, 2000 | 12:30 AM
4D THNDR's Avatar
Exclamation
<font face="Verdana, Arial" size="2">Originally posted by 99SVTBoy:
</font>
Definately have them check that #4 coil pack as the leaky hose on that coil is a known problem. PS, the SVT supplemental hand book on the '99's listed the wrong air filter # so even though that K&N number may not match what your book says it still may be the correct #. Call 1-800-FORD-SVT to get the right part #.
Red '00 Lightning,
Power Surge Performance enhanced,
Sound effects provided by Flowmaster,
375 RWHP,
445 RWTQ,
13.227@103.55
Track Videos
Old Dec 19, 2000 | 01:13 AM
LTNBOLT's Avatar
Cool
Silver_2000,
If your relying on the stock inlet your somewhat correct but the stock box has plenty of volume. You just need to let more air in. My gauge goes so far in the black with these 40 degree temps that it's scary. Here's the link with pics and the results on a 70 degree day.
http://home.midsouth.rr.com/lightningpage/airbox.html
Later,
Chuck
Black 00
Chuck's Lightning Page
Old Dec 19, 2000 | 01:27 AM
Post
Chuck
You are absolutely right the stock box is as I said too restrictive. I am not the type to chop my stock airbox so I bought a conical filter setup from PSP. That way in about 20 minutes I can pull the chip and replace the airbox and the dealer is none the wiser.
It sounds great and pegs the Joke Boost gauge just like yours. Mine pegs at 20 degrees or 110.
Doug
