AeroForce Interceptor Scan Guage????
Yes I have one and it works great, it will monitor tons of things in the ecu and takes tha place of many conventional gauges.
The readings i use the most are
IAT1 (intake air temp at the filter)
IAT2 (intake air temp after the intercooler)
Engine coolant temp
Trans temp
Maf voltage
Engine coolant temp
Trans temp
Maf voltage
Engine coolant temp
Trans temp
Maf voltage
Engine coolant temp
Trans temp
Maf voltage
Thanks,
I have it too mounted on the stering column pod, and like pitstain said it's awesome, the guy that sells them it's a member here and he has some on ebay.
I had one on my last car, almost the best mod I ever did for that car... its nice knowing exactly whats going on with everything in your car.. id recommend it to all you lighting guys..
sorry to get off topic, Jackal are you running Autometer Lunar gauges? they look almost exact match to the dash gauges. ALso which ones are you running...boost...water temp...
Yesterday 05:55 PM
Yesterday 05:55 PM
Those pics are mad!! DO you mind if I use/borrow/steal them Jackal?
