Looking for hole in firewall...
I'm looking for a hole in the firewall to run some wires for my speaker hook up from the battery. Is there one on the pass. side (pref near battery) that I am missing or what? I know there is one on the driver/center of the firewall, but that looks a little out of the way.
DUCK
November 18, 1999 We will not forget.
The fallen 12 will live in our hearts forever.
Fightin' Texas Aggie Bonfire 1999
DUCK
I ran one off the distrubution box (on the firewall), I ran it through the wire conduate (across the top of the fire wall, near the cowl) to the boost tap grommet, and into the passenger compartment.
Although this is the drivers side, I thought it was the best way.
I just drilled out a new hole and put my own grommit in.
99.5 red lightning
Cervini's ram air hood
billet grilles
clear coreners
clear tail's
A.R.E bed cover
SS street style mirror's
Super chip R9
airaid intake
trans go shift kit
Audio: Kenwood 9015 cd, Kenwood kmd minidisc, Kicker 5x7 impulse, kicker 5.25 resolution, phoenix gold zx450, Phoenix gold zx500, Three JL audio 10w3's, Qform's, custom built box.
Built 5/4/99 A tuesday
# 917 of 4000
Best ET. 13.42 at 100.98
best stock 13.96 at ?
When the green light drops, the bullsh*t stops.
99.5 red lightning
billet grilles
clear coreners
clear tail's
A.R.E bed cover
Super chip R9
airaid intake
trans go shift kit
# 917 of 4000
Me too...
Rich
1999.5 SVT Lightning - Red. 100HP Shot NOS, BellTech 3/4 drop, Super Chip(TRAC). K&N Filter. Viper Alarm w/remote start, Sir Michael's roll pan, smooth corners and steps w/billet inserts, clear corner lenses, Cervinis Ram Air hood, ARE Cover w/ wing, Momo billet pedals, cd changer, cover, Phantom boost and nitrous gauges, MTX Thunderform w/ 2 10" MTX Thunder 4000 subs. 5-channel 500w. Clarion amp.(APA5241), (4)Polk Audio 3-way, 130w. DX 7's, Color-matched Muth signal mirrors, Soundproofed cab, BedRug, Trenz billet grills, Piaa 9007 Super Whites, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt/
2001 PT Cruiser - Limited Edition
1999.5 Expedition XLT
Rich
I wound up using the one on the driver's side. I just drilled a hole in it and greased up some 4 guage wire so it'd slide through. Worked great.
FYI - I finally got everything hooked up and it sounds great.
I only went with 1 JL 10" (on a RF 360) and kept the factory highs (on a RF 120). They aren't bad, but I'll probably wind up replacing them after the chippenfilter mod. I'm not much into bass and stuff, just loud stuff on the highway or wherever, so I'm completely pleased. Thanks for all of y'all's help.
DUCK
I only went with 1 JL 10" (on a RF 360) and kept the factory highs (on a RF 120). They aren't bad, but I'll probably wind up replacing them after the chippenfilter mod. I'm not much into bass and stuff, just loud stuff on the highway or wherever, so I'm completely pleased. Thanks for all of y'all's help.DUCK
Another spot that worked for me was to remove the computer, pull my power wire through the easy-to-reach hole, and re-install the computer. Since it has a large rubber seal, and it was a single, 6 guage wire, it worked pretty good. It also worked out well to hide behind all the stuff on that side on its way to the battery. I've also used the distribution box before on my '92 F150.
1999 Lariat 4X4 SuperCab Flareside 5.4; Auto, Tow Pack, Offroad Pack, 3.73LS, Factory Step Bars, 17" Chrome Wheels, Oxford White/Silver, Graphite Leather, Keypad Mod., Airaid, SuperChip, ARE LSII Bed Cover, Alpine CDA-855/JBL AMP, Polk dX7's, Custom cat-back exhaust.
Look under the threshold trim piece. There is a channel that has a couple rubber grommet type plugs. I used the one closer to the front and pulled the wire beneath and behind the battery. Just punch a hole in the plug..pull your wire. I tie wrapped it along the frame. Worked well I thought, plus no DRILLING...
[This message has been edited by Twisted99 (edited 11-27-2000).]
I ran mine from the battery, to the wiper cowl... under the cowl up near the passenger door... down the door crevice, and into the wiring boot that leads into the passenger compartment for the door wires. This worked great, because there is NO drilling, and its really easy to access.
My PPI 75 watt per channel main amp is located behind the passenger kick panel, So this was ideal! I then continued the cable under the door threshold trim, to underneath the passenger seat, for my crossover and mono bridged 600 watt sub amp.
