question about lowering shackles
Old Mar 10, 2007 | 11:42 PM
hillman's Avatar
i just got a 03 lightning and the first thing i want to do to it is drop it. it is pure stock. i just want it leveled out so it looks good but doesnt go bottoming out everywhere and i dont want to buy new tires or anything. would 4" shackles in the back be good enough? what do you guys think i should do
Old Mar 11, 2007 | 11:36 AM
Rob_00Lightning's Avatar
4" Shackles wont get it quite level (cause it'll only drop maybe 2")
BUT IT'LL DEF LOOK BETTER
It's an extremely easy install, very quick, and inexpensive, DEF DO IT.
In the future if you want it even lower just pick up some L Leafs from an earlier year and your good to go (or take a leaf out)
("Beware a few Brothers had to re-adjust the pinion angle, but most didnt")
Old Mar 11, 2007 | 12:36 PM
hillman's Avatar
what would be a good set i could get?
Old Mar 14, 2007 | 07:43 PM
For the biggest drop as you said everyone goes for the 4" (as they call it) shackles.
JLP has some nice shackles and lots use them
You can get the 2" Shackles as low as $40 but you need more than that.
The other way to go is like this (the first 3 items you see on this page)
59.95 + 64.95 + 129.95 this set up will drop you more (they claim 4-1/2")
Or Items 3 or 4
189.95 or 229.95
Why dont you ask someone to post some pic's with the JLP Shackles installed on a 03 and see of it's what your after, it's an easy install.
The only prob with RPM is they Fk up pretty much every order so
Old Mar 14, 2007 | 11:37 PM
hillman's Avatar
thanks that was a lot of help, and ya is anybody using the 4inch shackles from jlp. can i get some pics
Old Mar 14, 2007 | 11:42 PM
there isnt much of a difference between the 3" and the 4" as far as the actual drop, and funcionality. I personally would stick to a 3" hanger and if you still want more drop, then get different leafs or different hangers.
-Patrick
Old Mar 19, 2007 | 09:51 PM
WhiteBolt04's Avatar
Here ya go....
This is an 04' with JLP 4" shackles on lowest setting. The same as 03'.
Old Mar 20, 2007 | 02:41 PM
MAT2CH's Avatar
Mine doesn't bottom out at all and it handles very nice, but it came like this when I bought it.
