NEW L. What to Know, What to do..
Old Mar 6, 2007 | 08:46 AM
cklepinger's Avatar
I have been looking through the forum here, and elsewhere, and thave read alot, but I am not sure where to begin...
I just bought an 01 L for 17K. 45K Miles... I love it.. but its bone stock except for the K&N Filter that was in it...
One thing that worrys me is this blown spark plug i have been hearing about... is there any way to prevent this? and they also say if you hear an exhaust leak, it could be a precursor to blowing out a plug and needing a new head? ?? I have a tad bit of a ticking sound on acceleration... so that worries me...
Aside from that, what else to look for when looking for problems?
now I am a turbo guy, and used to have a 13 sec 4.2 over at v6f150.com. So i am interested in the bottom end of the 5.4 SC. is this the exact same bottoom end as any other 5.4? with just a blower on it? also, I am not familiar with how you increase boost on these things... Something about the weight and size of the pulley? what is stock? I know it runs at 8 psi boost, so what would it take to run it at 10 or 12? I have an xcalibrator 2 from my old truck that i used for road tuning my 4.2 when turboed.. can i get a new pulley and have a tune ordered from somebody or should I have it dyno tuned?
All your guys help is appreciated....
Thank You
Old Mar 6, 2007 | 01:13 PM
Black02SVTL's Avatar
Good job on picking up the L.
First off, the plug problem. The best way is to just make sure your plugs are tight and keep checking them periodically.
Go with a 4lb pulley and a tune. When you get the pulley you will want to change the plugs to NKG TR6's. You should be able to use your XCAL2, you just need some dyno tuning. Power Surge Performance can hook you up. www.lightningparts.com
Old Mar 6, 2007 | 02:33 PM
todd abbott's Avatar
As for the plug issue, I swap them once a year this for me handles tightning the plugs, to increase boost they have both upper/blower pulleys and lower/crank pulleys to increase boost, next the lower end- the rods are the weak link anything after 450HP and your on borrowed time. Good luck, T
Old Mar 6, 2007 | 02:43 PM
Tim Skelton's Avatar
http://www.svtlightnings.com/faq1/faq.htm
http://www.lightningrodder.com/forum...splay.php?f=37
Also see sig below, and most importantly, the "search" feature above.
Welcome.
Old Mar 6, 2007 | 03:22 PM
cklepinger's Avatar
Thanks for the reply.. yea.. Im gonna start chaning out my plugs regularly, and check them at every oil change... Due Diligence...
do i need a new tune if I put on a 4lb bottom pulley? if I get a larger top pulley, what is tha advantages/disadvantages of this?
are the lightnings blowing out plugs left and right like it sounds? or is this just people that aren't as cautious as some that have that problem?
Old Mar 6, 2007 | 04:07 PM
See my post above.
Old Mar 6, 2007 | 09:42 PM
For your first mods, do a 4lb lower, programmer w/custom tune, cold air intake and a FTVB, this is a nice simple package next I'd add a catback, traction bars and an efan-while these won't really add power they add a fun factor.
Old Mar 6, 2007 | 10:21 PM
kromdom's Avatar
one of the first sites that I spent A LOT OF TIME reading is Tim Skelton's. In addition, this site also helped me sort out/prioritize mods: http://www.kennebell.net/techinfo/fo...ngTechTips.pdf
Old Mar 7, 2007 | 11:17 AM
Originally Posted by kromdom
one of the first sites that I spent A LOT OF TIME reading is Tim Skelton's. . . .
I have a lot of goodies in progress now. Watch for updates.
Old Mar 8, 2007 | 09:37 AM
cklepinger's Avatar
ftvb? What is this and what does it do... I know it has something to do with the valve body, but what is it? how hard is it to install and what are the pros and conns of it?
Old Mar 8, 2007 | 09:50 AM
Again, see my post above.
Stated another, and less polite, way:
Old Mar 8, 2007 | 12:32 PM
cklepinger's Avatar
post *****.... just kidding..
Old Mar 8, 2007 | 10:07 PM
LTNDave's Avatar
Factory Tech Valve Body
this iscreases the firmness of the shifts and is a great addition to help alleviate the sloppy and granny like stock shifts. If you want it to chirp the tires on a 1-2 upshift, this is the ticket to do so.
Old Mar 8, 2007 | 11:12 PM
kromdom's Avatar
article by Gregg about the FTVB
http://www.chickenears.com/accumulator.htm
