Determining the Air/Fuel Ratio?????
Old Nov 5, 2000 | 05:15 PM
Burninout101's Avatar
Question Determining the Air/Fuel Ratio?????
So how do you exactly determn the ratio of the misture and what gauge or gauges are used?
Old Nov 5, 2000 | 09:21 PM
Post
Come on someone has to be able to shed some light on this subject?
Old Nov 6, 2000 | 02:42 AM
DreaminAboutL's Avatar
Post
Burnin: air/fuel ratio can be determined by measuring the oxygen content of the exhuast. The stock O2 sensor in all modern day cars does this for the ECU. So you can get an Autometer air/fuel meter, tap into the O2 sensor and you're good to go.
The FAQ has install info.
More info here: https://www.f150online.com/f150board...ML/005798.html https://www.f150online.com/f150board...ML/006369.html
And Autotap also tells you: https://www.f150online.com/f150board...ML/006119.html
