Paging TBL - what's up with jack
Old Nov 2, 2000 | 07:35 PM
FlaSVT's Avatar
Banned
Question Paging TBL - what's up with jack
TBL - What kind of jack are you using to lift your L when you work on it? I have a heck of a time getting my 3 ton jack under mine and your truck is lower than mine. Maybe it's just the way I go about jacking it up but the first few inches are killer.
Rick
Email: ******@tampabay.rr.com
My Mods & More
Old Nov 2, 2000 | 07:43 PM
FORDSALES's Avatar
Post
My guess would be the 2.5 ton jack. The 2 ton jack does not raise high enough to raise a stock L. If the L was lowered a lot, maybe a 2 ton would work but if not, it takes a 2.5
Jim@FordMotor.cc
Black 00, #1008 of 4966, 4.10's, SuperChip/R9, JL’s Ram Air, chrome wheels,
AIM 2" drop, AutoMeter Boost and A/F Gauges, Valentine1,
Cobra Throttle Body, Mobile1 w/FilterMag
2000 E320, 1993 Cobra R, 1959 Corvette, 1949 Plymouth Coupe
Old Nov 3, 2000 | 01:50 PM
TampaBayLightning's Avatar
Post
2.5 Ton it is....
I lift the rear under the differential.
The fronts under the control arms.
It's a little difficult to get under the ground effects anymore but still able(barely).
Rich
Old Nov 3, 2000 | 03:32 PM
Nathan's Avatar
Post
Up front I cant get my 3 ton under the truck when I have low-profile tires on. I just take the stock jack or a small 2-ton I have and put it under the side framerail. Jack up a few inches and the front comes up enough to put the 3 ton in.
Old Nov 3, 2000 | 04:31 PM
BRIMSTONE's Avatar
Post
I was always told its a bad idea to use the differential as a jacking point. Is that BS???
Old Nov 3, 2000 | 06:20 PM
LSchicago's Avatar
Post
You guys just need a short piece of 2x12 wood! drive on it it & stop then you have an extra 1 3/4" clearance. Lloyd
2000 Black L #2189. Airaid & Superchip R9. Drag Results: Best ET: 13.07 Best MPH 103.09 Best R/T .501 (twice) Best 60' 1.631 on F1's 1973 Cutlass Supreme 455/450HP 4 speed. Too many Mods to list! 95 Olds Aurora 91 S10 305TPI/700r4 project 2000 freightliner FL60 Rollback tow truck My garage overuneth
Old Nov 3, 2000 | 09:45 PM
Post
Brimstone:
Bad idea only if you're crawling underneath.
