New Engine, Help??
Old Feb 20, 2007 | 08:09 PM
PensiveParoxysm's Avatar
New Engine, Help??
It is almost time to order my motor but was unsure of one thing. My L is a 2000
and needs a short block, the question is will my 2000 lower intake fit on a new 2003-04 block? I have heard that something is differnt on the lower intakes of the older L's, but what exactly is it? Or is there any retro fitting?
Also if i were to put my new heads on a new shortblock would my 2000 lower intake work?
Any help is appreciated.
Thanks,
Kevin
Old Feb 20, 2007 | 10:46 PM
birdy111's Avatar
should fit... IIRC the difference between the 99-00 and 01+ is a different intake runner design, and different bolt pattern for the blower to bolt to.
Old Feb 21, 2007 | 01:12 PM
LTNDave's Avatar
the blocks and heads are the same b/w the years. But the 99-00 intakes were a bit different than the 01-04's. The main diff being that the S/C used 6 bolts in 99-00 and used 8 in 01-04.
just going by memory
the later heads had more threads in the spark plugs holes but that was the only real diff on the heads.
