Custom tune
Old Feb 9, 2007 | 06:44 AM
skelly454's Avatar
Custom tune
If you have a custom tune sent to you by a repudable source,(mine will be form rpmoutlet) do you think it is still necessary to have your truck dyno tuned or to hook it up to an air/fuel meter? Also what are you guys running for air/fuel raito? Most that I have read said about 12.8:1, but I've heard you should be down around 12.2:1 with a supercharged engine. Thanks for the input.
Old Feb 9, 2007 | 08:01 AM
EnglishAdam's Avatar
It doesn't hurt to check that the tune is actually suitable for YOUR truck as each can have variations.
Maybe your fuel pump isn't quite performing right or your O2 sensors are a bit off.
Also, I don't know where you read about that 12.8-1 A/F ratio but it shouldn't be on a Lightning site.
You want to be around 11.8-1 maximum if not lower depending on ambient conditions.
Old Feb 9, 2007 | 01:36 PM
LTNDave's Avatar
At least have the tune check out at a local dyno shop. The A/F on the L's once modded should not be above 11.8:1 unless you like replacing motors.
Old Feb 9, 2007 | 05:44 PM
skelly454's Avatar
My mistake, I must have gotten the numbers mixed up. Weren't the 99-00s like around 10:1 and the 01s and higher at 12:1?
Old Feb 9, 2007 | 09:27 PM
Rob_99Lightning's Avatar
Originally Posted by skelly454
mine will be
May I add "if" you didnt already you may want to finish that sentence with the name of a Lightning Vendor. If we're talking a Filter Chip N Pulley Lightning any of the Big 3 here knows exactly what you need and you would be entitled to a free tweak or two....
Ya some L's are richer and some leaner but I never heard it being a full 2 ???
Old Feb 10, 2007 | 12:20 AM
skelly454's Avatar
such as lfp or jlp? I bought everything from rpmoutlet, so that may make a difference.
