Gates Blower Belt install...
Old Oct 13, 2000 | 08:48 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Thumbs up Gates Blower Belt install...
Just installed and road tested the Gates belt on the Red Rocket.
Took 10 minutes TOPS. Only tool needed was a 12" Craftsman (or equivalent) philips screwdriver.
Instructions:
Slip the screwdriver under the intercooler resovoir, resting in the tensioner pulley while leaving the tip under the "LIP" of the tensioner bracket.
push down on the screwdriver, keeping it at a slight angle, so it travels between the lower-left pulley and fan.
slip the belt off the lower-right pulley, release pressure on screwdriver, SLOWLY.
work the belt around the fan.
repeat above steps in reverse.
Initial thoughts:
The stock belt was beginning to glaze (14,000 miles)
Boost seems to spool up slightly quicker. No AJ248C noticable difference.
Maybe just me but I like have a shorter belt. The more tension, the lesser chance of slippage.
Can anybody say cog system????? JIM.......BABOLT..........
Brake Late, Dive Deep
Speedin Bob
'99 'Red Rocket' Lightning #2504, 6/17/99
NLOC # 438
13.56 @ 100.89, 1.97 60' on F-1's
JL Ram Air, R9 Chip,Keyless Entry, Retrax Bed Cover, Shackles, Wet Okoles, Mobil 1/FilterMag, Corners & Tails
Autophysics filter FOR SALE [9" x 3.5" Red Trim]
Old Oct 13, 2000 | 11:38 PM
clonetek's Avatar
Post
doesnt the tensioner have a square hole in it to accept a breaker bar? i looked & thought i saw one.
got my gates belt from a auto store here in town.. if i get out to the track tomorrow, i'll slip it on..
Old Oct 14, 2000 | 12:13 AM
JeffsLightning's Avatar
Post
When I installed mine I just removed the one top bolt and pushed the IC tank to the side. I then used a 1/2 drive ratchet and plugged it into the hole on the tensioner and took the pressure of the belt..
Old Oct 14, 2000 | 01:36 AM
Y2K_BOLT's Avatar
Post
Hey Speedin Bob.....I live in Terre Haute, and am in the Indy area on weekends occasionally. Drop me a email....fcrawford@prodigy.net
Old Oct 14, 2000 | 09:30 AM
clill's Avatar
Post
What is the Gates Belt part # ? Thanks.
