Thinking about a 01 Lightning for a DD....
Old Jan 21, 2007 | 10:11 PM
BrokeJoker's Avatar
I use to ride motorcycles but had to sell my toy to buy a house. Now that I own a house I need a truck. So id figure 2 birds with one stone and get a USEFUL toy.
I wont be doing much heavy hauling or pulling. Id probably never pull anything heavier than 3000lbs.
Is there anything I need to know about these trucks? im assuming they run on premium and only premium but is there anything else.
Im looking to spend about 15K on a used one, preferably silver
Old Jan 21, 2007 | 10:56 PM
birdy111's Avatar
you should be able to pick up a decent low mileage 99-00 or maybe 01-02 for around 15-17k. if you go with a 99 be sure to run an Oasis on it to make sure the IC fix has been done. Stock block is good to about 450rwhp.. bla bla bla i dont really want to type the rest of it out. Just do a search here or over on NLOC.net. THere is tons of useful information on these sites.
Old Jan 21, 2007 | 11:21 PM
BrokeJoker's Avatar
Excuse my laziness but what is the IC Fix?
Old Jan 22, 2007 | 12:31 AM
Stl01SVT's Avatar
I used my 01 as a DD for almost 5 years. I enjoyed it everyday, except when I had to fill the gas tank. You'll average about 13 mpg's with these truck.
Old Jan 22, 2007 | 02:11 AM
BrokeJoker's Avatar
Good thing Im 10 minutes from school and work.
Just wondering, what size tank, and can you only run premium?
Old Jan 22, 2007 | 08:29 AM
rtroha's Avatar
Yep they only run on premium and the tank is 25 gallons.
Old Jan 22, 2007 | 09:47 AM
Dan SS2471's Avatar
IC fix is the InterCooler fix. Most, if not all 99s had a leaky intercooler which should have been replaced via TSB under warranty way back when...
Old Jan 23, 2007 | 05:33 PM
BrokeJoker's Avatar
Another nooby question......what does a stock L run in the quarter?
Old Jan 23, 2007 | 09:06 PM
skelly454's Avatar
The 99-00s ran a 14.4 I believe and the 01 and up ran a 13.9 due to an improved air intake and 3.73 gears over the 3.55's that came on the 99-00.
Old Jan 24, 2007 | 01:03 AM
BrokeJoker's Avatar
So Im definately gonna want an 01
Old Jan 24, 2007 | 07:43 PM
skelly454's Avatar
maybe. I personally have an 00 myself. They are quite a bit cheaper than the 01 and up. Most people put an aftermarket air intake system on their trucks anyway so that take care of that issue. They did change a few other things like different shocks, aluminum driveshaft and clear tailights. I would go with a 99-00 if you want to save a few grand. Still a very fast truck. And the 3.55's are better if you drive on the interstate a lot.
Old Jan 24, 2007 | 08:44 PM
BrokeJoker's Avatar
All good advice.....
Being a DD the 3.55's may be the way to roll.
You wouldnt happen to know the be loading limit and the towing specs?
Old Jan 24, 2007 | 09:30 PM
skelly454's Avatar
the payload is 800 pounds and the towing capacity is 5,000 pounds. The later L's had a slightly higher payload due to different springs in back.
Old Jan 24, 2007 | 09:38 PM
BrokeJoker's Avatar
800lbs is pretty weak sauce for a truck bed......Ill probably never come close to both those numbers, but still
Old Jan 26, 2007 | 02:18 PM
halcyon's Avatar
I just looked it up on Edmunds.com, 03-04 max payload is 1400lb.
I didnt know it was that much.
