oil seperator?
Old Jan 13, 2007 | 01:27 PM
Mondo1's Avatar
1) Unscrew your clear bowl. being careful not to lose the rubber o-ring (that sometimes sticks inside the bowl housing)
2) Unscrew the barrel filter retainer (under the filter) until it comes out along with the upper filter sheild.
3) Take carb cleaner spray and soak it good..inside & out.(do not allow the carb spray to touch the clear plasic bowl..it will cloud the plastic)
4) Blow the pourous barrel filter with compressed air, or with your mouth over a hanky to push the excess cleaner out.Allow to air dry for 10-15 minutes.
5) Wipe the inside of the upper housing and assemble. Your good to go.
Old Jan 13, 2007 | 02:50 PM
Rio J's Avatar
Registered User
I have an LFP separator and I drilled a hole in the bottom of the stone all the way up to the housing cavity. It doesn't help with the oil vapor but it sure fills up fast now.
Randall
Old Jan 13, 2007 | 03:08 PM
Mondo1's Avatar
That is actually a good idea, but one must be careful not to let the oill fill up near that hole.I will try a very small hole in the filter element as an experiment. Good input!
Old Feb 5, 2007 | 10:54 PM
Dbl G's Avatar
Old Feb 6, 2007 | 12:38 AM
DirtY_Dave's Avatar
Originally Posted by pitstain
phsssssssssssssssssssssss_
Old Feb 6, 2007 | 12:43 AM
DirtY_Dave's Avatar
Originally Posted by Dbl G
I love this. Who makes this i cant read the top to good.
Old Feb 6, 2007 | 06:21 AM
Dbl G's Avatar
I do..
Old Jun 24, 2007 | 10:45 PM
01lightningsuper's Avatar
i likey
is there a filter in yours ??? is a filter better ???? could you email me on p&a Thanks
Old Jun 24, 2007 | 11:48 PM
STRK BY's Avatar
oil seperators are garbage and dont work, do a pcv delete.
I agree, old school motors never had any PCV BS, Just remote mount them for cheap and never look back or worry about cleaning the intercooler, or seperators, never worry about fouling out plugs and burning up oil..etc
https://www.f150online.com/forums/sh...ers....:beers:
Old Jun 25, 2007 | 12:01 AM
sorry
i like this set up and ment to qoute it.. DbLG whats the P/A on this separator. and is there a filter inside??
Old Jun 25, 2007 | 12:53 AM
Dbl G's Avatar
Yes there is a filtration system, They are packed with Stainless Steel steel wool..
Old Jun 26, 2007 | 06:40 AM
bnehila's Avatar
If you want to see just how much the compressor type seperators dont work... put another one after the first one and see how much oil gets past the first one. Breathers all the way!
