Red Indicator Light???
Old Jan 9, 2007 | 07:22 PM
mlentz01's Avatar
I'm a relatively new lightning owner (2004 model year). There is a tiny red indicator light on my dash to the left of the steering wheel that isn't covered in either the F-150 or Lightning manuals. Anyways, it blinks twice quickly every two seconds while the truck is in operation (used to do that only when when the truck was parked). Does anyone know what this indicator light signifies? Thanks.
Old Jan 9, 2007 | 07:30 PM
chief40al's Avatar
sounds like some type of aftermarket alarm.
Old Jan 9, 2007 | 07:34 PM
mlentz01's Avatar
You would think huh? The only alarm on the vehicle that I'm aware of is the standard Ford-installed one, as nothing about a secondary system was mentioned to me when I purchased the vehicle. I will try to follow up with the dealership I bought it from. Perhaps my mechanic can figure it out.
Old Jan 9, 2007 | 07:40 PM
chief40al's Avatar
A picture is worth a thousand words.
Old Jan 9, 2007 | 10:26 PM
Fast Gator's Avatar
Or in Rob's case, 1 word is usually good for 7 or 8 pics
Sounds like its an aftermarket alarm armed indicator light
Old Jan 9, 2007 | 10:30 PM
pitstain's Avatar
there is no factory alarm installed on Lightnings, post up a picture.
Old Jan 10, 2007 | 11:33 AM
mlentz01's Avatar
Per the comment about Lightnings not having standard alarm systems, my 2004 Lightning has an "Alarm" indicator light in the main dash gauge area that blinks when the truck is turned off and my standard keyless entry system includes an alarm button, so I am pretty sure I have a factory alarm.
That little white thing is the indicator light. It used to blink (along with the "Alarm" indicator in the gauge display) when the truck was turned off, but now it appears to be constantly blinking (twice quickly every 2-3 seconds).
Old Jan 10, 2007 | 11:59 AM
Robert Francis's Avatar
That indicator is tied into your alarm system. I have the same thing on my 01L which I bought new in July of 01. I'm not totally sure how it works, but mine normally blinks all the time the vehicle is sitting - and when it's "armed" blinks rapidly and when I try and start it, the lights and horn go off.
Old Jan 10, 2007 | 12:01 PM
pitstain's Avatar
I am sorry for not being as clear as possible before, we have a PATS system (Passive Anti Theft System) the keyword being passive. It is more of an immobilizer than a real ACTIVE alarm system, if you jimmy the door open there will be no alarm, if you break the glass or open the hood, again no alarm. all it has is a panic button and a flashing indicator.
what you have in that pic is absolutley NOT factory, but could possibly be an indicator for an aftermarket alarm, or some sort ot temp indicator for something, maybe even a switch chip indicator.
Old Jan 10, 2007 | 12:57 PM
mlentz01's Avatar
Thanks guys. Mine definately used to act like an alarm indicator light, but now blinks even when the truck is on and moving. I'll have to check into this further from the dealer and my mechanic/electrician.
Old Jan 10, 2007 | 03:05 PM
STRK BY's Avatar
Trace the wires comeing fromt the light, that will tell what it is going to and therefore what it is, It may be an Antitheft deterent light, not tied to the alarm but just there to flash so a theif will see an armed alarm system and hopefully just walk away........
Old Jan 10, 2007 | 03:23 PM
Rob_99Lightning's Avatar
Nice guess there Sport
mlentz01 it could be a Lojack, I have one in my L and have a red light there too. If it is you can push the light or a little square button under it (if you have one) and arm/unarm the system that way too, I think the key has to be on (I've done it a couple of times but forget)
Old Jan 10, 2007 | 05:37 PM
mlentz01's Avatar
Clearly this is the most helpful site around for my stupid questions. Thanks everyone.
