Transmission Differences b/w Bolt years &/or Harley?
Originally Posted by whip
To quote Al Borlan.....
I don't think so Tim
Hope this helps,
G
Unless it was an advertising scam you are wrong. When they switched from 3.55 rear gears to 3.73's, they changed the OD to compansate for the top end. I have not seen part numbers for the two trannies, so they could be the same, but I know for a fact the published ratio's are different.
Originally Posted by TrackBeast
I don't know why you're stuck on this and I really don't care for such a trivial issue. You were very quick to point out that I was wrong and you dismiss accurate data because a picture of an 01 is used. I have original 99, 00, 01, 02, 03, 04 brochures, technical manuals, and everything I have read etc., etc and absolutely everything indicates 0.71. You dismiss everything and yet you can't pinpoint the origin of your information. You are one stubborn guy. You're beating a dead horse. Man! I'd hate to be married to you... Like I said, either way I really don't care. Have a peaceful evening.
I can even scan the factory build sheets if you want, but the OD never changed ratios.
