any suggestions???
Old Jan 8, 2007 | 10:31 AM
SRTthis's Avatar
any suggestions???
http://www.svtperformance.com/forums...d.php?t=351576
any suggestions on how to get this bolt out???
Old Jan 8, 2007 | 12:52 PM
BriteRed20s's Avatar
Bolt removal
Grind the head of the bolts off, lift the blower off, then you can see if the bolt is stripped in the casting. Extract the bolt with vice grips, turning while lifting using a prybar under the vice grips. Install helicoil and a new bolt.
