abs light
Old Dec 27, 2006 | 03:03 PM
svtmike24's Avatar
abs light
ive have also noticed that after i lowered my truck that my abs light stays on anyone know why?
Old Dec 27, 2006 | 03:33 PM
Ricki F-150's Avatar
Have you disturbed the sensor cables that run to the front hub yoke.
If these are not connected or damaged the light will come on - fail to safety.
Check for loose connection or damage.
These cables run from the inner arch area above the front suspension and connect to the hub rotor sensor. It's a black flexible cable about 6mm thick.
Check both sides.
Old Dec 27, 2006 | 06:07 PM
svtmike24's Avatar
thanks for the help ill look into that tomorrow i got the day off whoo whoooo
Old Dec 27, 2006 | 06:37 PM
pitstain's Avatar
get on a wet parking lot and slam the brakes to see what locks up, it may be the rear abs sensor on top of the diff pumpkin, I broke mine when installing my hellwig swaybar and I'll tell ya it sure made drifting easy
Old Dec 27, 2006 | 10:50 PM
svtmike24's Avatar
thanks for the tip ill check that out when i look at the other ones tomorrow!
