lowering...
Old Dec 27, 2006 | 12:11 PM
svtmike24's Avatar
lowering...
ive had the belltech 3/4 drop now for a while, and there is more gap in the front then on ther rear.
i would like to know how i get my front down a little more...?
its just been bothering me lately and i cant get it outta my head. here i am at work and cant even concentrate thinking about this damn truck haha well anyways any help would be great!
Old Dec 27, 2006 | 01:32 PM
r1killen's Avatar
that's easy
if u did drop spindles witch only give u 2 inches but keep ur camber perfect u can add a drop spring, then drop top a arm ,,,then bottom a arm but u should not nead that........ u could bag her but then u cant take turn to fast....
Old Dec 27, 2006 | 07:00 PM
pitstain's Avatar
svtmike,
I assume you used a drop spring up front, if so did you put them in correctly? and did you use the top spring pad from the stock springs?
the proper way the spring should be installed is with the end of the coil covering one and a half of the two little holes in the lower spring pocket.
also removing the top rubber pad from the spring will drop it another 1/2" or so.
Old Jan 9, 2007 | 12:55 AM
jdmdc529's Avatar
Do you have it on the top most whole on the rear shackle?
Will any noise be made from removing the rubber on the top of the spring ? Will it really lower it a 1/2" ?
