need help with low idle and misfire
so my trucks been misfiring and when i hooked a scan tool obg2 up 2 it it said cylinder 5 misfiring, so i replaced plug and coil because it smelled burnt, the spark plugs tip was also craked off. well its raining today so can't really get on her but drove her around a little and when i pull up to a red light she idle's at about 500 and it's really low and the truck kinda shakes it's bad i also cleaned the throttle body and replaced the pcv valve last week thinking that would help what can i do....
actuallly
i only changed the number 5 plug and it still idle's low,,,ur truck is nice man, i bet it's faster than my gsxr-1000 anyways ....i'm waiting to see if the svs light comes back on and i wonder if it does what code it will throw....
u mean change all the
change all the plugs.....and when i change the fuel filter whats a good way not to get sprayed i have the speacial hose remover is it pressurized though and u recomend motorcraft plugs
Originally Posted by r1killen
i did change the pcv i think pass. side block rear but were is the idle air control valve.
It is the shiny gadget on the passenger side of the intake plenum. Usually a carb cleaner wash gets these things going for a while, sometimes it just needs replacement. It needs to be removed in order to clean it. Wouldn't hurt to include a fuel filter change as well. If that fails, on to the plugs and checking coil packs.
Originally Posted by Rob_99Lightning
Did you change "ALL" the plugs or just #5 ???
If you only changed #5 COMPLETE the job and your truck will run normal
again, then you need to figure out why it happen ???
what do u mean by complete the job?
i did check the plugs and it said bank 5 misfirin
so i replaced bank 5 plug and coil pack because it smelled it still is rough shiny thing im gonna go clean it and se what happens
do u mean the silver thing with a gasket on it remove and clean inside?
Dan
When you hurt (break, melt, or damage) "1" plug, you most likely hurt MORE Complete the Job meant --> CHANGE ALL PLUGS <-- sorry I didnt explain better
Thanks for the compliment, yes it's insane outright scary even
Here's the IAC info
https://www.f150online.com/forums/sh...light=Cleaning
