Dyno numbers
Old Dec 21, 2006 | 10:51 PM
Sharpshooter's Avatar
Dyno numbers
Mods:
JDM Longblock
Whipple (8lb lower 3" upper) ~ 20 psi
JDM street tune + 2 degrees using the X-Cal =14 degrees of timing
Dyna tech Headers
Catless Midpipe
Stock Cat-back
Supporting Fuel mods.
Temp-76 F Humidity-48%
This was the 2nd Run. The first was 5 minutes before this one, and netted 599.84 RWHP. Both runs were made imediately after a failed dyno attempt due to a downshift. So the truck was hot. This is a mail order tune from JDM to get me by until I can make it up to N.J. early next year. Hopefully next year I can be added to the long list of 10 second JDM trucks
Old Dec 22, 2006 | 06:55 AM
AustinSVT's Avatar
awsome! how much $ do you have into this engine package?
Old Dec 22, 2006 | 08:16 AM
scv8's Avatar
Congrats! Is this on pump gas?
Old Dec 22, 2006 | 10:18 AM
afchad's Avatar
Good numbers!!!!
Old Dec 22, 2006 | 10:44 AM
01Diablo's Avatar
Nice numbers
Old Dec 22, 2006 | 11:18 AM
Rob_99Lightning's Avatar
niiiiiiiiiiiiiiiiiiiiiice
CONGRATS and WOO HOO!!! got to love these big *** Superchargers
Old Dec 22, 2006 | 12:15 PM
pitstain's Avatar
I just wish it wasnt so dammed ugly, I have no choice but to go whipple when i upgrade.....maybe by the time i do theylll have the 3.3 available.
Old Dec 22, 2006 | 05:07 PM
Thanks guys.
I mixed 114 with 93 just for peace of mind.
Old Dec 22, 2006 | 11:07 PM
NCsvt2003L's Avatar
Nice numbers, pushing the boost a little on the fuel mix? Turn up the timing and go C-16 and see what she puts out!
Old Dec 23, 2006 | 10:02 AM
Lets face it the L engine compartment was never know for looks (either is a Stangs compartment for that matter).
Since I drive with the hood closed to tell you the truth I dont give a rats *** what it looks like under there
Putting down 589.23 / 686.62 STD with only 10lbs of boost (due to that slipping belt issue we had,
NOW FIXED) on 93 Octane pump gas tells me this KB can hold it's own......
For the record I agree the Whipple looks Better, but both SC's seem to put down equal HP on the same set up,
(I also have a 8lb lower and 3" upper). I think it's AWESOME to have multi options to Bolt on MASSIVE HP now.
Plus some race only trucks may opt for the KB "H" Model (15lbs Min Boost recommended) 50 HP over my model
Their priced the same (KB maybe a little cheaper) and the KB seem to have more Tq, it's good to have choices
NO REASON FOR WARS AND BASHING....
All I know is putting down equal #'s with Sharpshooter's Beast here has me all excited.
Congrats again Sharpshooter isnt it AWESOME to have this kind of insane power on a street tune
Old Dec 23, 2006 | 10:55 AM
Ronnie,
I had the octane around ~ 104, no sign of detonation. I plan on getting a C-16 tune when I get a dyno tune. Hoping for some mid 600 numbers.
Originally Posted by Rob_99Lightning
: isnt it AWESOME to have this kind of insane power on a street tune
It sure is. On the street I will be running a bigger upper with around 15psi. It seems useless to have over 675 ft/lb's on drag radials.
Old Dec 23, 2006 | 11:32 AM
I hear you I can rip my DR's lose up to @ 60MPH if I stab it
I already bought a new Upper for mine and planned to pull 5lbs of Boost also
(bought a 3.5" upper). Sal tried to swap pulleys for me last weekend but my stock upper wont come off, we even snapped a hardened steel Snap On Socket trying (@$^%(@$@)$%@$)%@$
I dont know if it'll ever come off but I'm having A LOT of fun as it is I'm using it pretty much everyday now and enjoying the schitt out of it, maybe once the snow hits I'll send it in to have the pulley removed. I too want the option to be able to swap pulleys, as you said having @700 ft lbs of tq at such low RPM is outright tire ripping and makes it pretty dam impossible to get on it except for in OD (and then only if you do it slow and steady)......
Old Jan 1, 2007 | 12:40 AM
madferraristi's Avatar
IMO, the limit for street tires is somewher in the high 500's. Anything more than that and you have to be damn careful.
