Does Removing The Fender Tube On THe Factory Air Box Increase Air FLow?
I was looking under the hood of my L today, and noticed how small the air tube is coming out of the fender into the factory air box. I was wondering if removing that tube would increase air flow? Would the L increase horsepower from removing this tube?
HANKFAN
HANKFAN
Hankfan,
I removed the tube. Folk wisdom imparted to me indicated it would help.
If THAT helped, I reasoned, why not drill a mess o' holes in my airbox to get even more air in there? So I did that, too.
Ran a 13.507 w/ the swiss-cheese airbox on Thursday, which was 1/10th sec faster than my all-time best w/ an open-mouth filter kit.
The air was cooler Thursday, so the head-to-head comparison isn't completely valid, but the ***-o-meter would indicate anything getting more air into the filter is a good thing.
OTOH, you'll be sucking in more warm air from the engine compartment.
Regards,
Gordon
'99 Red Lightning
Johnny Lightning Superchip
Johnny Lighting Stage II Ram Air Kit (coming soon)
Century Tonneau
Regards,
Gordon
'99 Red Lightning
Century Tonneau
I left the boot on mine because it's sucking cooler outside air. I put a K&N replacement filter in and gained right at 2lbs. of boost. I then cut a large hole in the bottom of my airbox closest to the drivers side headlight (coolest air there) and gained another .5lbs. of boost. If your stock you'll have to put mufflers on preferably straight thru or this will slow you down. Proved it at the track.
Refer to post: SLOW L
Later,
Chuck
Black 00
[This message has been edited by LTNBOLT (edited 09-23-2000).]
Later,
Chuck
Black 00
Unless I go in complaining of air leaks in my airbox, I don't see what the problem would be.
Besides, my JL Ram Air gets installed next week.
Regards,
Gordon
'99 Red Lightning
Century Tonneau
[This message has been edited by BadDog (edited 09-24-2000).]
Regards,
Gordon
'99 Red Lightning
Century Tonneau
I've found the warm air wasn't really a factor. I didn't go swiss on mine, so still got the option of sneaking my L back to the dealer claiming no mods if I ever had to. A butchered air box isn't exactly the impression I want them to have of how I treat my vehicles. The Pro-m doesn't seem to offend them that badly, and can be changed back to the factory airbox in no time.
Cheers
2000 Lightning (Red)
SHM Chip and Mass Air
SHM Blower Pulley
378.2 @ 5100 HP
445.0 @ 3600 ft-lb (before pulley)
Kill Count = 28 suckers picking rubber off their teeth.
SHM powered - www.seanhylandmotorsport.com
'99 Cobra - SHM engine, Vortech supercharger, and to many other mods that my wife don't know about.
Cheers
SHM Blower Pulley
378.2 @ 5100 HP
I recommend drilling a 2" hole with a fitting, attached to a hose going to cooler air. MORE POWER !
Lloyd
2000 Black L #2189. Airaid & Superchip. Drag Results: Best ET: 13.41 @ 101.07 Best R/T .501 (twice) Best 60' 1.95 1973 Cutlass Supreme 455/450HP 4 speed. Too many Mods to list! 95 Olds Aurora 91 S10 305/700r4 project 2000 freightliner FL60 Rollback tow truck 1989 Ford F450 Wrecker My garage overuneth
Lloyd------------------
