Nitrous and Stock Plugs????
Old Sep 23, 2000 | 02:15 PM
1BADTK's Avatar
Thumbs down Nitrous and Stock Plugs????
Running nitrous and stock plugs isn't a good idea. These only had 26 passes on them with anywhere from a 50 shot to a 100 shot. Only two passes with 100 shot most were on the 50 shot. If you are going to run nitrous or are running nitrous, CHANGE THEM NOW!!!!
http://nloc.org/ubb/Forum7/HTML/000129.html
SeeYa Round!
Old Sep 23, 2000 | 02:25 PM
BulldogSVT's Avatar
Banned
Post
ouch...what did you replace them with?
Old Sep 23, 2000 | 03:36 PM
WA 2 FST's Avatar
Red face
D'oh! That's horrible, Andre. I'm just glad the engine isn't hurt. You did say Ford did a compression test, right?
You have just proven a critical tuning issue when playing with forced induction. I see this all the time with Mustang owners who bolt on blowers and don't use the right plug (colder is mandatory). Same thing obviously goes for a factory blown motor...I'd be willing to bet if people upped the boost too much (like to 14psi or so), they'd need the same thing: a colder plug, a correctly gapped plug, and new fuel/timing curves.
Wes Tarbox
90 LX 5.0 (10.69 @ 134.7)--597rwhp/590rwtq
96 Cobra (12.34 @ 115.8)--392rwhp/433rwtq
99 Lightning (13.20 @ 103.8)--364rwhp/444rwtq
00 Expedition XLT 5.4
http://members.aol.com/Wa2fst/index.html
Old Sep 23, 2000 | 06:32 PM
LTNBOLT's Avatar
Exclamation
I hope the tops of your pistons don't look like those plugs.
Good Luck!!
Later,
Chuck
Black 00
HANKFAN's Avatar
Post
Does anyone know which NGK plug I should use if I plan on running a NOS dry system?
HANKFAN
Old Sep 23, 2000 | 07:09 PM
Chains's Avatar
Post
NGK Part # 4177TR-6
2000 White Lightning
Alternative Auto Chip
Alternative Auto Blower Overdrive Pulley
Flowmaster 2-chamber 40 series
Air-Raid filter
M/T 26x11.50x16 ET Streets
Best ET 13.39 Best MPH 104.66
Old Sep 23, 2000 | 07:49 PM
n20boy's Avatar
Post
I can remember way back when I worked for NOS systems we would tell our customers never run platinum plugs. They cannot handle the extreme heat! Melted electrodes..hhmmm not good.
I would recommend a different plug..NGK?
DONT RUN A PLATINUM PLUG!!What do you guys run for a gap?
later,
seb
[This message has been edited by n20boy (edited 09-23-2000).]
Old Sep 23, 2000 | 08:05 PM
1BADTK's Avatar
Post
BullgogSVT:
Replaced them with NGK TR6's.
WA 2 FST:
Did my own compression check, all were within 15 LBS of each other. Going to have Ford put it on the scope Monday and see if anything is in the memory. Truck runs like itself again and maybe a tad better with R9.
N20Boy:
I gapped them at .045, NGK says .054 but these plugs are not Lightning Specific, FORD calls for .045 and they came out of the box set at .043 + or-.
LTNBOLT:
I am with you, the ones I could see looked OK but going to scope all them next week.
Conclusion:
Don't I say DON'T run nitrous with the stock plugs, E's or M1's, they are both platinum. I can not tell you if the NGK's are the right choice either, but I am going to find out. Someone out ther with plug savy could tell us if they are colder or not.
Later Dude's
