Hey JohnnyLightning!!!
Old Sep 21, 2000 | 07:44 PM
videoman's Avatar
Cool Hey JohnnyLightning!!!
Hey JL-Dan here,
Just recieved the Rear 10" EAGLES and boy do they look good.
Also I am re-installing the Ram air and the Cooler will be installed next Week.
Saw you truck in 5.0 magazine (also Fast Fords now) in this months issue. Nice win-DUDE!!!! Lost a subscription on that buy out!!
Take care,
Dan
Dan
99.5 Vermillian Red SVT Born on date:
8/24/99 # 2094
N.L.O.C # 461
F1 Hood
Full Bassani Exhaust
PSP TOTALLY ENHANCED-4-way chip,filter
Level 10 Trans Kit
4.10 FMS Gears
JohnnyLightning Ram Air
Beltech 2" Drop
And the list keeps growing!!!
Best STOCK 14.22 @ 98.36 in 90+ degree weather
BEST et w/ mods to date:
13.59 @ 102.49. on F1's in 90 + degree weather
13.23 @103.98 on M/T E.T's w/1.91 60 ft in 89'degree weather
THANKS SAL!!!!!!
"TEAM PSP"-Fla. Chapter
Old Sep 21, 2000 | 10:55 PM
JohnnyLightning's Avatar
Wink
Dan the Man.......i'll be ordering tommorow..
i'll be testing my new program tommorow night i'll keep ya posted.JL
93 cobra 10.90@127.00
99 lightning (black)
e.t. 12.85 @ 105.1
best mph 105.4
60 ft. 1.85
superchiped
johnnylightning ram air
Level 10 shift kit
(man i luv this truck)
SuperChip distributer
JLightningPerf@aol.com
Old Sep 22, 2000 | 12:24 AM
bobcmt's Avatar
Post
Dan,
Glad you liked the 10" 589's, I had same thoughts. Tubes were expensive, @ ~$95 and did I tell you you will need to drill stem hole to 5/8"? The bit will set you back ~$15 if you have to buy one. Fit was good and balance too inspite of my earlier concerns. If still looking for tires, try 407-843-3873, ET Streets start at $149.95.
L in shop now for IC install. 11.50's were very stable on big end with only 14-16 psi, think I will need less air pressure, based on tit wear. Truck was too weak (IC) to check contact width. I will have too wait till its healthy again.
Same problem with mag subscription. As I recall I had just re-upped for two years. Have you heard if we will get out scripts extended? Eager to hear results with ice box when you trial it. Later. Bob
[This message has been edited by bobcmt (edited 09-22-2000).]
Old Sep 22, 2000 | 12:50 AM
videoman's Avatar
Cool
Good to hear it JL.
Bob-Thanks for the info on the rims. I don't think I am going to run tubes, just yet. Found 11.5s locally for $160.00 es. Figure freight on the $149.95s and I'll only be saving about $5.00 ea. Not worth the hassle. Get them mounted Sat. The fronts should be in tomorrow.
The cooler will be on and tested next Weds.Test and Tune along with JohnnyLightnings Ram Air and single bore throttle body. Will The mods ever end???
Dan
