still not starting!!!!! 3 codes..
Old Dec 10, 2006 | 01:54 PM
Hostile03SVT's Avatar
Originally Posted by JollyGiant
If waiting for a stainless "Y" is not practical, you can build a workable solution with a brass T, an elbow, 3 barb fittings, and a short straight piece of 5/16 pipe.
Dude you are the man!! thanks for all your help im just waitin for a couple of friends to lift this thing its all unbolted and unplugged just waitin to be lifted..
Hey Rob i can see why you wont drive to Jerzy to help me, your too busy on the net!!! LOL
Old Dec 10, 2006 | 05:05 PM
BLUE N BLOWN's Avatar
had the same problem with my truck after i had new pumps installed. coming off an off ramp i go to give it gas and truck shuts off completely and would not start back up i had to get it towed. turned out one of the lines on the new pumps were too clamped to tight.loosened it up and ran like new
Old Dec 10, 2006 | 05:31 PM
problem solved!!! pulled the bed off today and removed the pump assembly, and what do i see? the fuel line came off the pump!!!! re-installed it after i inspected everything else there and fired right up!! 39-40PSI idle hit the gas and it raises.. sounds like a great day now tomorrow i will order some QA1s and do that while i can access the top shock bolts..
THANK YOU EVERYONE WHO HELPED WITH YOUR SUGGESTIONS I APPRECIATE ALL YOU HAVE DONE!!!!
Rich
Old Dec 10, 2006 | 05:51 PM
LightningTuner's Avatar
Rich
Isn't that the first thing I told you to check??
Old Dec 10, 2006 | 05:59 PM
Rob_99Lightning's Avatar
He dont listen Sal. At least he let me convince him to pull the Bed, I found him step by step pictures and all, (for the record I WOULD NEVER DO THAT)
So now he's running and he gave his troubles to me @^$R)@&$^%@)$_@$
Glad it worked out Rich (I still say you should race it WITHOUT the Bed) hehehehe
Old Dec 10, 2006 | 06:22 PM
lightninquick's Avatar
my inside source says it was just out of gas
Old Dec 10, 2006 | 06:50 PM
Ricki F-150's Avatar
He He - better keep quite if that was the case... Eh Rich.
I still reckon he had some entertainment in the cab and she got her heel jammed in the cut out switch.
So was it a bang for the buck
Old Dec 10, 2006 | 11:29 PM
No.. Sal, you told me to check for preasure and the fuses..
Old Dec 10, 2006 | 11:32 PM
When you said you had no fuel pressure, but you heard the pumps running, I told you to check the lines in the tank .
Old Dec 10, 2006 | 11:52 PM
yea you did.. thanks dude!!
Old Dec 11, 2006 | 06:28 AM
I told you he dont frigging listen, he's like me
OR SOMETHING
Here's your Pic's Rich
Old Dec 11, 2006 | 09:41 AM
thanks for hosting my pics Rob.. you da man!!
Old Dec 12, 2006 | 09:24 AM
tallimeca's Avatar
nice
glad you found the problem.
I got my y fitting from LFP. I own a hardware store and couldn't find a fitting of that size without order like 25 of them!!!
Obviously, you didn't want to take the bed apart again, i don't blame you.
I had a disaster when i took mine off.
Did the whole job by myself with my post lift. When i backed the truck up under the bed to drop the bed back down, i forgot to raise the bed up all the way my tire caught the bottom corner of one of the ground effects and snapped it in half!!!
Old Dec 12, 2006 | 01:32 PM
dude i saw the same thing.. someone who did theres with a lift posted pics and the cracked there body skirt too.. sam just happy to have it running again..
Old Dec 13, 2006 | 10:14 PM
BoneStockSVT's Avatar
I'm glad you fixed it Rich.. Perfect for upgrading some suspension components now.
