Electric cooling fans
Old Sep 12, 2000 | 11:34 AM
Big Poppa's Avatar
Post Electric cooling fans
Hello all..
Has anyone replaced the mechanical cooling fan for an electric setup? I know PSP and SHM were supposed to be comming out with something soon.. Just wondered if anyone has beat them to it.
Got Boost ?
1999 SVT Lightning
Old Sep 12, 2000 | 03:46 PM
Spiro99SVT's Avatar
Post
Big Poppa,
Unfortunetly I have not heard a word from PSP on any new products, I plan on installing an 18 inch electric fan before the next gathereing. This is also good for dropping some weight.... Just be sure to use the stock shroud. Hope this helps
Spiro-TEAM PSP
BLK. #1476
Best run to date
12.753 @107.98
Best 60` 1.84
Best m.p.h. 107.98
@ 4700 lbs.
"Empty Pockets Racing"Drag Race Team NJ-DE
Spiro99SVT@aol.com
LAUNCH HARD
Old Sep 12, 2000 | 05:56 PM
seniorchief's Avatar
Talking
Check out seanhylandmotorsport.com/lightning
Electic Fan Kit, they claim to save 10 to 12 HP.
seniorchief
95 Cobra
2001L on order
Old Sep 13, 2000 | 12:54 AM
HIGH RISK's Avatar
Post
I've had them on since last fall. No problems at all even in summer heat with A/C running. Flex-a-lite dual 12" PN FLX-210 $199.95 in the Summit catalog. You can then ditch the factory shroud. Unless you would like to keep the extra weight.
HIGH RISK
Old Sep 13, 2000 | 08:01 AM
ZorPrime's Avatar
Talking
Ordered a fan kit that fits inside the stock shrowd and comes with all the goodies.2800cfm@20 amps.I like the stealth look.
High Risk,
How much does the stock shrowd weigh?How much HP did it free up on your truck?
[This message has been edited by ZorPrime (edited 09-13-2000).]
Old Sep 13, 2000 | 02:52 PM
HIGH RISK's Avatar
Post
Not sure on exact number of HP but the stock fan is a pretty heavy piece. I don't think I've ever seen a fast drag car without electric fans. Don't know how much the shroad weighs either but any weight is no good. There is no part lighter then a part that isn't there
HIGH RISK
[This message has been edited by HIGH RISK (edited 09-13-2000).]
Old Sep 13, 2000 | 06:36 PM
videoman's Avatar
Question
ZorPrime-Question? Can you give me any more information on the fan kit you purchased to replace our sea slug of a fan clutch?
Email me at DWRella@webtv.net if you prefer.
Thanks,
Dan
Dan
99.5 Vermillian Red SVT Born on date:
8/24/99 # 2094
N.L.O.C # 461
F1 Hood
Full Bassani Exhaust
PSP TOTALLY ENHANCED-4-way chip,filter
Level 10 Trans Kit
4.10 FMS Gears
JohnnyLightning Ram Air
Beltech 2" Drop
And the list keeps growing!!!
Best STOCK 14.22 @ 98.36 in 90+ degree weather
BEST et w/ mods to date:
13.59 @ 102.49. on F1's in 90 + degree weather
13.23 @103.98 on M/T E.T's w/1.91 60 ft in 89'degree weather
THANKS SAL!!!!!!
"TEAM PSP"-Fla. Chapter
Old Sep 13, 2000 | 06:46 PM
ZorPrime's Avatar
Post
HighRisk,
Well said...that fan is outta here!
Its actually a kit for the 5.0 but will work for our rods as well.
Interactive Systems Tech.
800-820-1082
Supercool Electric Fan kit
I will be doing the install in the near future.Ill let you know how it pans out.
Old Sep 14, 2000 | 12:22 AM
HIGH RISK's Avatar
Post
Zor,
The install is pretty easy. The top an bottom of the radiator have a piece of track with holes in it. Use the plastic brackets that come with the fans to mount them. I've seen people have problems with those zip tie things that come with the kit. I had to double clamp the top rad. hose where the temp sensor goes in but besides that it is pretty straight forward.
Good Luck,
HIGH RISK
