Broke on the way home from Norwalk.
To those of you who have experienced fuel pump problems. Do you wait until the tank is almost empty before refueling, or do you do it beteen 1/4 and 1/2 or so? Since the fuel pump is in the tank, it is depending on being submersed in fuel to keep it cool when running. Once the fuel level gets down so far, then the pump will not be covered, and it may overheat, thus causing a failure. Especially if you refuel like this most of the time. Just a thought....Also, I thought these things had dual fuel pumps. If so, wouldn't one be enough to get home on?
Mike
White 99 #837 5/3/99
A.R.E Cover
BedRug
PSP Filter
NLOC #0380
Mike
A.R.E Cover
BedRug
PSP Filter
NLOC #0380
Follow up:
I ot the L back today at lunch. the fuel pump was replaced, they "found" the intercooler and added the dye so as to test for leaks.
They instructed me to "run it with boost a few times" my retort: "are you sure?!, it gets loud and kinda scares me when i do that ."
Thanks for the replies.
I GOTTA PUT MY CHIP BACK IN. I can really tell the difference without it.
Brake Late, Dive Deep
Speedin Bob
'99 Red Lightning #2504 Built 6/17/99
NLOC # 438
13.98 @ 98 mph (Rookie Session)
Latest Mods:
AIM Drop shackles (on order)
Superchip [CUX1R9]
Keyless Entry
Retrax Bed Cover
2000 L Tiedowns over 99's
Super White Head and Fog lights
Wet Okole Seat Covers
Mobil One and FilterMag
Airaid w/ Autophysics filter retrofit
Clear Corners & Tails
Bugflector
Duraliner
Speedin Bob
NLOC # 438
Latest Mods:
Superchip [CUX1R9]
Keyless Entry
Retrax Bed Cover
Bugflector
Duraliner
