How do you burp the intercooler system?
Old Nov 20, 2006 | 07:40 PM
TampaBlack99's Avatar
Mine has a huge air bubble in it.
Old Nov 20, 2006 | 08:42 PM
pitstain's Avatar
reply on nloc
Old Nov 20, 2006 | 09:17 PM
KIRST8404's Avatar
squeeze the top hose going into the i/c tank while the system is running. you can watch it from the side to see it working.
Old Nov 21, 2006 | 03:49 PM
l-menace's Avatar
start your engine and let it run. the IC tank is also a degasser tank.
Old Nov 28, 2006 | 08:52 PM
Gooberlog's Avatar
Burping intercooler coolant after drain and fill...
With the intercooler top on right?
Planing on flushing out all of my fluids, new owner of a '00 L
Old Nov 29, 2006 | 07:56 AM
wydopnthrtl's Avatar
That's no tpossible unless there is something blocking one of the lines.
Simply running the pump will purge all air out of it within a minute.
Rich
Old Nov 29, 2006 | 03:19 PM
You mean like a air pocket?
Old Nov 29, 2006 | 03:39 PM
Incogneto's Avatar
Sometimes the system will get air trapped in it. If you can use a rag and your hand to form a seal along with shot of compressed air into the filler hole while the engine is running. That usually does the trick and forces the fluid down and into the pump and subsequently back through the system.
Old Nov 30, 2006 | 09:30 AM
TriPodRacing's Avatar
Just jump out the IC pump and do as above. Works like a charm.
Old Nov 30, 2006 | 10:50 AM
Same thing I was told on another board and it worked. System runs fine now.
I found once doing the above I was able to open the valve on the bottom of the H/E and let the air out. Once the water ran solid I closed the valve and then topped off the overflow tank.
