Useing this wide band?
Old Nov 2, 2006 | 10:43 AM
LightningToGo's Avatar
Gauge-Type Wideband UEGO Controller
http://www.aempower.com/ViewCategory.aspx?CategoryID=67
Old Nov 2, 2006 | 11:34 AM
Hostile03SVT's Avatar
i use it.. works great.. i have not tried to data log with it though..
Old Nov 2, 2006 | 12:17 PM
EZ SPEED's Avatar
I like it . . . I have two of them . . .one for each Lightning. I datalog to my SCT Raptor with it.
Old Nov 2, 2006 | 01:17 PM
Who has best price?
Old Nov 2, 2006 | 01:53 PM
RPM outlet $279.. but.. i think you can order it from AEM direct.. if so it miight be like $225.........
Old Nov 2, 2006 | 08:09 PM
Is this better for $400?
Old Nov 2, 2006 | 10:43 PM
lightningkylej's Avatar
I believe both use the same type of 02 sensor. However, you can not replace the sensor when it goes out on the AEM Uego, if it ever does.
Whatever guage you get, be sure and put in a few feet away from the heads to keep the high temperatures away from it. That will make the sensor last a lot longer.
I use the PLX M-300, found it for $150 used and it works just fine.
Old Nov 3, 2006 | 09:44 AM
typhoon43's Avatar
I have the Innovate LC-1/XD-1 combo and it's awesome. The gauge is totally customizable, down to changing the LED colors for each peg, I have mine set to be blue when under 11.8 A/F, then RED for anything higher. You can also datalog to a laptop very easily. It's a wonderful setup.
Old Nov 3, 2006 | 03:09 PM
JollyGiant's Avatar
I just purchased a sensor from AEM. $78 shipped to Hawaii.
Old Nov 3, 2006 | 04:24 PM
Bill Bell's Avatar
[QUOTE=lightningkylej]I believe both use the same type of 02 sensor. However, you can not replace the sensor when it goes out on the AEM Uego, if it ever does.
Here's a place to buy the sensor for $64.99
http://www.jegs.com/webapp/wcs/store...tegoryId=10625
