Got Them Platinum Plug's Out!
Old Aug 21, 2000 | 07:33 PM
FSUFAN's Avatar
Post Got Them Platinum Plug's Out!
Just a little note.
I took the platinum plugs out today and replaced them with NGK V-Power Non-Resistor Racing Plugs, Part # R5671A-7.
The are just a little colder which will help when spraying nitrous, but the one main thing is they are a hell of alot a safer.
Matt
2000 Lightning, Chassis Tech Drop Kit, 80 mm Pro-M Mass Air, w/ K&N Filter, Danny Swanson Flip Chip, Flow Master 40 Series Exhaust, Billet Upper & Lower Grill, 100HP Nitrous Oxide NOS System. 12.533 @ 109.10 MPH
GO FLORIDA STATE SEMINOLES
[This message has been edited by FSUFAN (edited 08-21-2000).]
Old Aug 21, 2000 | 08:00 PM
MRBBQMAN's Avatar
Question
FSU, i've had better luck with NGK's V-power, than any other plug, when it comes to blown nitrous. i used champion racing plugs and experienced detonation no matter how cold a range because of the retracted ground, which exposes a huge spark across the gap. does the NGK Racing plug have a retracted ground, like to the side of the electrode, rather than over it?
Old Aug 22, 2000 | 07:52 AM
Sudsfixer's Avatar
Question
Were You having problems with the platinum plugs, or was it a safety issue?
I read that platinum plugs and nitrous don't work well with each other.
00 Silver
Sudsfixer
Old Aug 22, 2000 | 10:46 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Post
FSU,
How do they affect normal, non-juiced, driving?
Brake Late, Dive Deep
Speedin Bob
'99 Red Lightning #2504 Built 6/17/99
NLOC # 438
13.98 @ 98 mph (Rookie Session)
JONESING FOR CHIPPAGE!!!!!!!
Latest Mods:
Retrax Bed Cover (on order)
Super White Head and Fog lights
Wet Okole Seat Covers
Mobil One and FilterMag
Airaid w/ Autophysics filter retrofit
Clear Corners & Tails
Bug Shield
Duraliner
Old Aug 22, 2000 | 11:25 AM
WA 2 FST's Avatar
Question
Anyone out there written up a procedure on removing the plugs on this vehicle? I consider myself an above average shade-tree/home garage mechanic, and I'm sure I could figure it out.
But it looks like you have to remove the coil packs, maybe the fuel rails, etc.
I can pull plugs on my Mustangs in 20 mins and that's inspecting each plug with a magnifying glass looking for stuff. This truck looks like a PITA.
Wes Tarbox
90 LX 5.0 (10.69 @ 134.7)--597rwhp/590rwtq
96 Cobra (12.63 @ 114.5)--392rwhp/433rwtq
99 Lightning (13.20 @ 103.3)--364rwhp/444rwtq
00 Expedition XLT 5.4
http://members.aol.com/Wa2fst/index.html
Old Aug 22, 2000 | 04:34 PM
FSUFAN's Avatar
Cool
Hey Guys,
The plug-changing job was really not that bad. I did not have to remove anything but the coils, which are on top of the spark plug of course.
Took me about 2 hours to do them and the front 4 took 30 min. and the back two took me 1 hour and a half.
They are working just fine for just normal driving, didn’t notice any difference at all.
Jerrod: no noise at all that I can detect.
Speeding Bob: Normal operation is just the same.
Sudsfixer: I was having no problems with the platinum plugs, just wanted to get them out because of the nitrous application. So really just a safety issue!
MRBBQMAN: The electrode is retracted in the housing, but the ground is over the electrode still. Hope that helps your question.
Good Luck Changing Them Plugs!
Matt
[This message has been edited by FSUFAN (edited 08-22-2000).]
Old Aug 22, 2000 | 04:49 PM
Post
Thanks Matt
boy betweent hethis board and mods for my "L", I'm in deep doo doo with Mrs. Speedin Bob.
Robert
Old Aug 22, 2000 | 04:50 PM
Post
Thanks Matt
Boy, between this board and mods for my "L", I'm in deep doo doo with Mrs. Speedin Bob.
Robert
Old Aug 22, 2000 | 06:57 PM
Bill Murray's Avatar
Really Old "Member"
Post
Just for grins guys, and I mean just for grins!!
After reading this post, I went downstairs to my garage and pulled out my plug wrench and pulled out and reinserted the plugs on my '56 F100 with a Racing Head Services built 300 Cu.In. Ford straight 6 with full Clifford equipment and triple side draft DCOE 45 Webers. This beastie dynos at a tad over 300 horsepower,and while it won't beat my Lightning I suppose, it screams and is torque personified.
Anyway, total elapsed time, including opening a rather ratchety hood mechanism was, not on a stop watch, about 9 minutes flat. After 2 pretty stout Scotch on the Rocks I might add.
99.5 Lightning
Build #247
PSP Chip/Filter
Bassani full system
White/normal options
Tamiya 1/10 scale Bolt
Several old trucks/cars
Thunder & Lightning
Rag Doll Cats
E-mail MOSTOYSINC@AOL.com
Kennesaw, Ga. (Atlanta)
Old Aug 23, 2000 | 12:17 AM
MRBBQMAN's Avatar
Post
Wes, Sal describes the procedure on his site in Tech Help, tech tip #1
Old Aug 23, 2000 | 12:32 AM
99SVT's Avatar
Post
Matt, are you having any problems with static noise since they are a non-resistor plug.
Would be nice to use the colder plug, thinking about running nitrous on the beast and I do want to get those plugs out of there before I have the same problem Sal had.
Jerrod
Jerrod
99.5 White Lightning
SHM mass air/filter
PSP chip
Full Bassani exhaust
4:10 gear
FRPP oval throttle body
BFG Drag Radials
104 oct. unleaded
Snuglid bed cover
sprayed on bed liner
phantom boost gauge
smoked driving light covers
best 1/8 - 8.43sec
best 1/4 - 13.21sec
both at high 90's temp
