heli coil brands
Old Oct 16, 2006 | 03:43 AM
light you up's Avatar
heli coil brands
Hey all
what type of heli coil would be best for a 02 L
and what are the best and longest lasting spar plugs to install
also if I want to change out the heads and stay with my stock engine
what would be a good set of high performane ported heads to replace the factory heads any good brand names would be helpful and prices on how much they might cost
thanks all
bill
Old Oct 16, 2006 | 12:34 PM
LTNDave's Avatar
helicoil is simply a brand name (although they do make a good spark plug thread repair kit)
As far as spark plugs if its stock use the motor craft factory plugs.
As far as the head go with the Patriot heads, not sure on the cost.
hopes this helps
Old Oct 16, 2006 | 02:54 PM
Bad as L's Avatar
The only ones I've seen made from aluminum: http://www.fulltorque.com/sparkplug.htm
If I had to do it again this is what I would use.
Dale
Old Oct 17, 2006 | 04:32 PM
thnder's Avatar
http://www.timesert.com/
The only answer IMHO
