Vibration at Cruise Speeds (70 - 82
Old Aug 14, 2000 | 06:29 AM
Robert B. Chuhran's Avatar
Angry Vibration at Cruise Speeds (70 - 82
Just started having vibration at cruise speed
and it really is a pest. Just rotated tires
after a couple of months and don't remember
this much or even if it did with other tires
on the back.(lot less rubber almost a 1/8)Has
any had the problem an found what it might be. I will put on the drag radials and test
to see if it is that group of tires that is the cause.
cause.
Robert B. Chuhran
Old Aug 14, 2000 | 10:40 AM
2000Trade-In's Avatar
Post
I've just noticed the same problem. It seems to be most noticeable at 80 to 85. At 90 it doesn't seem as bad. I also noticed it seems to be more noticeable on a slight grade up hill. Anybody know whats up?
Old Aug 14, 2000 | 11:03 AM
4D THNDR's Avatar
Question
You did rotate them front to back and back to front and not crisscross right?
Red '00 Lightning,
Adopted 4/19/00,
Power Surge Performance enhanced,
Sound effects provided by Flowmaster,
13.701@100.81
Old Aug 14, 2000 | 01:21 PM
Black2000L's Avatar
Post
I also have some vibration, although it occurs at higher speeds above 90mph. Now i just installed the the lowering shackles, should i replace them with the stocks before i take it to the dealer dont want to have an warranty problems. By the way the vibration was there before. One the i notice is when i frits notied it i was doing 110mph, then i noticed it at 100mph and it just kind of seems to keep getting to lower speeds. Thanx for any help.
Mauro A.
Old Aug 14, 2000 | 02:23 PM
Post
I rotated mine front to back. I sure hope it's not a plug or coil. But now that you mention it it is taking a little longer to start too.
Old Aug 15, 2000 | 12:32 AM
fribab's Avatar
Post
I had the same problem with my 2000. It ended up being 2 bad plugs, a coil and i still have a bad injector that has been on B.O. for weeks. After these were repaired
i lost the vibration. Hope this helps...
Bryce
Red 2000 Lightning, SuperChip, Flowmaster, Granatelli Mass Air Meter
