Installing Upper... HOW!!!!!
Old Oct 3, 2006 | 08:32 PM
sadf's Avatar
I have the eaton puller and got it off fine. I even have a pully puller/installer from Autozone however, none of the threads match upper to the blowers. What next?
Old Oct 3, 2006 | 10:45 PM
dirtchicken's Avatar
Get a washer and a longer bolt with the same threads. Grease the shaft on the Eaton and use the longer bolt to push the pulley on. Once it's on a little you should be able to use the stock bolt for the pulley to finish the job. I've done two uppers on my truck that way.
Old Oct 5, 2006 | 02:50 PM
brahmus's Avatar
Put it (the pulley only) in the oven for a few minutes on 250 or so.. NOT to hot. Slide it on with ease (using an oven mitt) and let it cool on it's own!
What pulley tool from Autozone did you get?
Old Oct 5, 2006 | 08:13 PM
Certified Drunk's Avatar
Too bad Rob went to the It's a Jeep and we will never.....
Anyway's this might help
http://www.lightningrodder.com/forum...read.php?t=248
