Best Oil for Lightnings?
howdy,
does anyone know what's the best synthetic motor oil out of these?
- valvoline synpower
- royal purple
- redline
- amsoil
my lightning has only 900 miles on it. i've heard it is recommended not to use full synthetic until 3,000 mi. some say, 6,000 mi. is this true?
thanx for any info.
- royal purple
- redline
- amsoil
thanx for any info.
Any one of the synthetics you can't go wrong with. If your truck has 900 miles on it I wouldn't add synthetic until it has a few thousand miles. You need to get the rings fully seated first. That's why they advise against using synthetics to break a fresh motor in.
Originally Posted by SLATECREEK
I use mobile 1 or royal purple and they both work great. I wouldnt use anything else in my Harley Truck.
you don't know if you don't ask????????
i have JDM BUILT MOTOR
They Recommended 5-20 Motorcraft
Originally Posted by JeffsLightning
What did they recommend?
Yeah I was supprised how thin it was - like ****
But it's what Ford reccomend.
And my engine builder / tuner reccomemded.
It's not easy to get here in the UK so when I bring something in from JDM
I will add a case or two each time.
Not using synthetic motor oil to break in a motor is a myth. The only thing I wouldnt do is put it in a fresh rebuilt motor because you drain the oil so quickly(50-500miles). That would be a hit in the pocket book but other than that there is no problem. And also rings seat in about the first few minutes of starting a new engine and they will seat just fine with synthetic.
Zach@D.I.D. Racing
www.didrace.com
Zach@D.I.D. Racing
www.didrace.com
Originally Posted by Ricki F-150
Jim at JDM said "Use This One"
All bedded in now, oil,filter & plugs changed.
Ready to Dyno on 29th Sept.
Jim is right on he knows what works best for our lightnings
