What size belt?
Old Sep 18, 2006 | 09:47 AM
TampaBlack99's Avatar
What size belt?
For a truck with a 2# upper and a 2# lower?
Old Sep 18, 2006 | 12:23 PM
LTNDave's Avatar
"This is from another post"
stock length-66"
stock lower/2.75" upper/stock idlers-65.5" belt
stock lower/2.8" upper/stock idlers-?
stock lower/3.5"upper/aux idler w/90mm and 100mm-69"
4lb lower/2.75" upper/stock idlers-
4lb lower/2.8" upper/aux idler/90mm and 100mm-68.5"
4lb lower/stock upper/stock idlers-67.5"(very tight)
4lb lower/3.5" upper/two 90mm idlers-68.5"
4lb lower/3.5" upper/aux idler/two 90mm idlers-69"
4lb lower/3.25" upper/stock idlers-68.5"
5lb lower/3.5" upper/stock idlers-68.5"
6lb lower/stock upper/stock idlers-68.5"/69"
6lb lower/2.7"upper/stock idlers-68"
6lb lower/stock upper/Aux Idler w/two 100mm-69.5"
6lb lower/3.25 upper/69"(tight)
6lb lower/3.5" upper/90mm idlers-69.5"
8lb lower/stock upper/Metco aux idler w/two 100mm-69"
8lb lower/2.75" upper/stock idlers-67"
8lb lower/2.80" upper/aux idler w/two 90mm-69.5"(tab removed)
8lb lower/3.25" upper/stock idlers-68"
8 lb lower/3.5"upper/aux idler w/two 90mm/tensioner tab removed-69"
10lb lower/stock upper/stock idlers-72"
Old Sep 18, 2006 | 03:27 PM
LatemodelRacer2's Avatar
I ran the stock belt on just a 4lb lower back in the day so i see no reason for the stock belt no to work on a 2lb upper and 2lb lower
