Supercharger Snout problem ?
I bought a 2.80 pulley to put on the L but it doesnt fit. once its pressed on it wont spin. its locked against the snout. so i took it back off and looked that the snout. it is alot thicker on the left side than it is on the right. the pulley clears the right side with no problem but of course get locked down on the left.( right and left sides are looking at the charger.) ever heard of this before ?
I remember reading about others that experienced this issue here a few years
back. You have to be careful whos ( Manufacturer) upper pulley you buy as some will NOT clear the snout as you mentioned...Any legitimate Vendor would make sure you obtained the proper one for your application..
Doesnt make sence because people have been using 2.8's for many years with no problem, I did on two diff Eatons. AMOF I had a 2.7 on my last Eaton and that went on with room to spare (and NO grinding) ???
I've heard of a few having to grind a little for 2.7's, (not the JLP 2.7's though)
but never for 2.8's. Does it look like the snout has more meat on one side ? Or could it be a really bad Pulley or the wrong one as ProMod said ?
I have decided to dremel down the left side just a bit. like i said before the pulley clears the snout except for the left side. i looked at the pulley last night again and it clears all of the snout expect for maybe a spot thats about 1/4 inch long. so if i dremel that spot down it should spin freely.
In any case, it is better not to use an aluminium pulley on a steel shaft. Its cheaper to make a pulley that way. Compare to the stock pulley or ask any machinist. I know that some have not had issues but I'm just saying it is better. Both metals expand at a different rate and the aluminium could come loose and damage the snout.
TB
It clears just perfect!!
