Dyno tune 01 lightning
Old Sep 2, 2006 | 05:54 PM
Kane's Avatar
Took my 01 lightning to the dyno shop the other day and only pulled 307 rwhp, and 475 tr. The truck has a 6lb lower pully, cold air induction kit, boost bypass, ram air induction hood ( which puts the cold air onto the 12 inche filter ), flowmaster exhust, and a helix bore spacer. This also include the guy doing a custom tune. Now he says that there dyno is true, and gives the correct readings. Any takes on this, it cost me $600.00 bucks.
Old Sep 2, 2006 | 06:19 PM
69-mustang's Avatar
No takes but what is a helix bore spacer?
Blwnsvt01's Avatar
Wow
I think i would try to get my money back and try somebody different
Old Sep 2, 2006 | 06:37 PM
todd abbott's Avatar
With those mods your I think your numbers should be higher, 360rwhp is pretty much stock, 400 with a chip, pulley, CAI, for 500.00 I can have JDM do a dyno tune and there considered to be expensive, as for a custom tune I'd have them redyno the corfirm the numbers them send the sheets to the tuner of your choice and get a tune from a repuitable L tuner, something is not right. T
Old Sep 2, 2006 | 08:01 PM
Falcon11's Avatar
Was your intercooler pump working? There is obiviously something wrong. You sure your blower belt was on?
Old Sep 2, 2006 | 08:49 PM
Hostile03SVT's Avatar
dude with a filter and a 6# and a BS diablosport factory tune i made 360hp425tq... i would def. find another dyno shop...and tuner... good luck to you..
Old Sep 2, 2006 | 10:31 PM
Kane's Avatar
A helix bore spacer goes between the throttle body and the intake plentium, it spins the air intake for a smooth and cooler charge. Like the tornado on tv, but also gives a 1inche spacer in the process.
Old Sep 2, 2006 | 10:34 PM
69-mustang's Avatar
Got ya, thanks!
Old Sep 3, 2006 | 08:07 AM
afchad's Avatar
306rwhp
I would be checking to see if my intercooler pump was working
Old Sep 3, 2006 | 10:08 AM
Johnny A's Avatar
Hey Kane there are a few of us headin to Houston Raceway Park Tonight if you have time come out and play.
Old Sep 3, 2006 | 02:30 PM
Kane's Avatar
Have to work tonight, is there a good tuner shop in Houston, and where is it located. I`m in Port Arthur TX.
Old Sep 3, 2006 | 02:34 PM
Kane's Avatar
How do you check the intercooler pump ? the truck still runs strong, just that the numbers are off.
Old Sep 3, 2006 | 02:39 PM
Kane's Avatar
Also this is the second motor, the frist one decided to let a piston head go through the passenger side of the block, ( third one back on the passenger side) this would be the same one that a year before shot a plug out. Yet ford replaced the engine, blower, and blower intake under warrenty, cost me $50.00.
Old Sep 3, 2006 | 03:12 PM
Johnny A's Avatar
Kane I sent you an email.
69-mustang's Avatar
With the truck running just pop the hood and see if there is coolant swirling around in the reservoir.
