500 hp question
what mods would it take for my stock 04 lightning to be in the 500 club? :banana:
A KB blower or Whipple, Full exhaust, injectors, maf, plugs, pumps,throttle body:lol:, lower pulley and a great tune to make it run right, this is what worked for me.
Hmm i am still new to the lightning but from what i understand. The rods are only good up too 500 hp and that seams to be a little push for the engine. Also for 500 hp your going to have to go to a bigger SC to move some more air into the engine. also your going to need a lot of good tuneing to pull it off. I think that 450 to 475 is about the most you want to push but ever one on here is great and if i am wrong they will correct me.:thumbsup:
Kenne Bell 6lb lower pulley (15psi) Dynatech long tubes Silver bullet cat-back / high flow cats / mid pipes Electric fan Cobra R pump AFCO heat exchanger JLP powercooler C&L plenum / elbow 95mm MAF CAI MAFIA extender 60lb injectors Walboro 255 pumps Underdrive pulleys NGK BR7's Accufab SBTB FTVB (r) PI 2600 stall QA1 shocks Diablo revolutions chip I have done everything you can pretty much except the internals. But you can probably get there cheaper with the following: Ported blower 6lb lower NGK TR6's Predator or SCT tuner (good dyno tune) CAI FTVB 100 wet shot / nitrous :rocker: |
i make 500hp/600tq on the dynojet.. i have a ported eaton, sbtb, crower stage 2 cams, 2.7 upper, 6 lower, long tubes hiflow cats, silver bullet cat back, c&l upper, 60# injectors, sctba2400 MAF, AEM 95mm intake, on a killer PSP tune....:thumbsup:
Rich |
I'm there......
551 RWHP and 580 on the torque. I am only running 13.5 psi of boost......:D
JLP built and TUNED with a KB sittin' up top. Planning on going with his new intake and pushing the boost up to about 18 psi. That should put me at about 600 RWHP.:rocker: |
Has anyone ever installed just a 'Big Shot'?
I mean like nothing, just a 150-175 shot? Just wondering :confused: |
I mean like nothing, just a 150-175 shot? Just wondering :confused: Yeah.............Rob And you remember what his motor looked like when Sal took it apart? Hello almost spun rod bearing:lol: |
Ported blower
6lb lower NGK TR6's Predator or SCT tuner (good dyno tune) CAI FTVB 100 wet shot / nitrous :rocker:[/QUOTE] steig ported blower, 4# lower, ngk tr6's, airraid cai, bassani bx midpipes and catback, predator tune. safe and or aggresive tune! where will i stand as far as numbers go? ive read many posts and preety much they all say that a 6# is perfect for the ported blower |
I mean like nothing, just a 150-175 shot? Just wondering :confused: just wait until this spring... there will be a gen 2 with a much larger shot than that! |
FF :lol: |
