MT DRAG RADIALS QUESTION
Old Jul 15, 2000 | 06:14 PM
noelvm's Avatar
Exclamation MT DRAG RADIALS QUESTION
Well, I have been experimenting with 104 percents for several weeks. As most of you know my truck is bone stock except for a K&N in the box. I've been running BFG drag radials and in the 1/8 turning best 8.93 with an avg around 9.0. I've been running a 33% mixture of 104 to 66% 93.
Last night I had a 50-50 mixture. Before I could launch at 800-1000, but last night I spun the tires big time. My times were as bad as 9.45 and my 60's were awful. A good 60' for me is 2.09. Obviously, I had too much hp for the tires. When the sun went down I was finall able to launch at idle and turned a 8.96. What good is horsepower if you can't hookup, right? So on to another expenditure-- MT drag radials.
I see that there are two sizes that will fit the 16" rims that I am using-- 26X10.50R16 and 26X11.5R16. Seems like the 11.5s would be the ones to use. Is anyone running these and will they fit?
noelvm
99.5 Red Ligntning, Syn Oil, Eldebrock 5512 muffler, BFG drag radials, Bugflector, G&H Lens covers,
70 Vette LS-6
Old Jul 15, 2000 | 06:18 PM
Wyldman's Avatar
Post
Noel,
Those are the ones I've been using!
Wyld
Old Jul 15, 2000 | 06:26 PM
noelvm's Avatar
Talking
WYLDMAN,
8" rims??
Old Jul 15, 2000 | 07:54 PM
1BADFRD's Avatar
Post
Noel-
I have got the 11.5's also. They fit fine on those 7.5 inch wide ford rims I got.
Alex
Old Jul 15, 2000 | 08:18 PM
SilverBullet's Avatar
Post
They "fit" does not mean they are correct fit. That said I wouldn't recommend the 11.5" on the standard wheel, but if you must, make sure they are screwed in.
I have a ford 7.5" rim with the 10.5"s.
Old Jul 15, 2000 | 08:36 PM
1BADFRD's Avatar
Post
Technically speaking, Silverbullet is correct. An 8 inch rim is recommended for an 11.5 inch wide tire. Practically speaking, from my own experience, I don't have any issues/problems with mine. The combo works well together, and I am glad I got the wider tire.
Alex
Old Jul 15, 2000 | 09:08 PM
noelvm's Avatar
Question
Alex,
What air pressure were you running last nite?
Old Jul 15, 2000 | 09:41 PM
Caka's Avatar
Post
Hey Noel, I have the 11.5s and the recommended rim is 9 or 10in but will work on an 8in. I have the 10in rims as you probably remember, and have the tubes also. I though I waisted money on the tubes but after talking to Wyldman I now think I did the right thing, his seem to go almost flat while sitting around not in use. I run 16lbs of pressure but as much as 18 or 19 seemed about the same to me. My rims, tires and tubes, mounted& balanced all together were $560 at discount tire. More than I wanted to spend but well worth it. Get em!
Old Jul 15, 2000 | 09:52 PM
1BADFRD's Avatar
Post
Noel-
Dang, you really have to be specific hear. The MINIMUM recommended width rim is 8 inches. The wider the better. 7.5 inch rims seem to work fine, you be the judge??? I was running 18 lbs last night. I agree with Caka, tubes might be a good idea. Mine went flat in two weeks, not a big deal if you use them every week and check the pressure, but a nice to have anyway.
Old Jul 15, 2000 | 10:55 PM
BABolt's Avatar
Lightbulb
Got a question? When did M/T start offering Drag radials. I know that there are ET Streets and ET Drags but not aware of a Drag Radial. Would like to see one. Who uses ET Drags and who uses ET Streets? Do you see a difference?
BABolt
SVT#290
Old Jul 15, 2000 | 11:40 PM
Caka's Avatar
Post
They mean Street Slick ETs not DRs
Old Jul 16, 2000 | 04:08 PM
noelvm's Avatar
Talking
My apologies BABOLT. We're talking about ET Street (tm) Nylon, black, tubetype, D.O.T. passed catalog # 3793 tires.
