Where to wire ground for electric gauges?
Old Aug 13, 2006 | 01:58 PM
Falcon11's Avatar
Installing an Autometer electric boost gauge. Where do you guys wire the neg. (ground) on the MAP sensor?
Old Aug 13, 2006 | 02:14 PM
LightningTuner's Avatar
Any metal part of the dash frame will work. There is also a ground screw to the body under the driver's kick panel (it's green). That's what I like to use.
Old Aug 13, 2006 | 02:23 PM
Falcon11's Avatar
Huh, autometer says to use an engine ground?
Old Aug 13, 2006 | 02:27 PM
MISTERgadget's Avatar
the engine grounds to the body and frame, so using one in the cab is equivalent.
Old Aug 13, 2006 | 02:37 PM
I put the MAP sensor under the dash. It's a nice spot, since you can just tap right off the factory boost line tee. Then grab all your power and ground wires under there.
Old Aug 13, 2006 | 02:44 PM
Falcon11's Avatar
O.k. thanks guys, I'll just make it easy and ground to one of the screws on the dash then.
Old Aug 13, 2006 | 05:50 PM
Mickey_shouse's Avatar
under the drivers kick panel is where i have mine
Old Aug 13, 2006 | 06:57 PM
Don's Bolt's Avatar
Thats where I have my MAP Sensor too.
Old Aug 14, 2006 | 12:12 AM
Hilander's Avatar
Thats the Baro Sensor right? Why put it inside the truck?
Old Aug 14, 2006 | 03:09 AM
Tim Skelton's Avatar
Why put it anywhere else? Unless you have a pressurized cabin . . .
Old Aug 14, 2006 | 09:51 AM
No, no, no... They are talking about the add on MAP sensor that's used with electric boost gauges.
