How to find a Tool to get the Radio out
Can someone let me know where to buy a tool to do this.
A Ford mechanic said Snap-on had them but I can't find them anywhere in a new catalog I jut received.
I need to remove the radio and have the bezel chromed etc.
I prob have some laying around if you cant find them
This place has the Ford Tool in stock for $6.75
http://www.discountcarstereo.com/detail.aspx?ID=174
Oh looky here, Walmart has them for $3.96
http://www.walmart.com/catalog/produ...90202953216048
What do you know anyway, you own a jeep!!!
Nice to see you around here! Bryan
Go to your closet.....Grab a metal coat hanger....cut it, bend it in a U shape, and insert into the hole
actually i found another way to do it. very easy too. I did it in my old 99 explorer with the same stupid clip needed for that.
the plastic holding ur headunit should pop off. just clips holding them in, once u pull it off you will have some room to play with it and you can see how the radio is held in, just push at it with a flat head screw driver i believe.
good luck
good luck
