4x4 pan on a lowered L?
Old Aug 6, 2006 | 09:31 PM
Dman25's Avatar
My truck has a pretty radical drop, 3/4 and i was thinking about doing the FTVB mod and 4x4 pan, do u think the 4x4 pan is a bad idea since the truck is so much closer to the ground?
Old Aug 6, 2006 | 09:59 PM
203Cree's Avatar
Yes, go with the MOROSO pan instead.
Old Aug 7, 2006 | 01:54 AM
madferraristi's Avatar
In order to be 100% safe with my lowered truck, I built my own that does not hang down below the frame rails.
Old Aug 7, 2006 | 05:51 AM
bnehila's Avatar
i have a 4x4 pan on ebay right now if your interesred.
Old Aug 7, 2006 | 06:10 AM
TXSVTLIGHTNING's Avatar
I'd get the FTVB, but skip the Ford 4x4 pan and get the Moroso.
Old Aug 7, 2006 | 07:25 AM
SVT_KY's Avatar
It's the first thing to hit on Dead Policeman
Old Aug 7, 2006 | 10:38 AM
Dman25's Avatar
does the morso pan hang below the frame rails? im thinking i might just keep the stocker at this point.
Old Aug 7, 2006 | 09:42 PM
Silver-Bolt's Avatar
4x4 pan with a Hotchkis drop.
Old Aug 8, 2006 | 07:39 AM
SILVER2000SVT's Avatar
I was running a 4x4 pan when I first did my 2/3.5 drop. It lasted a little over a week before it got crushed in on a hump in a parking lot. I ended up going with a cast Al MAC pan and don't have any more ground clearance issues with the pan. The problem I have now is even after 3 brand new pan gaskets I can't get the AL pan to stop leaking.
Old Aug 8, 2006 | 09:16 AM
Mondo1's Avatar
Many aluminum pans come out of the casting warped. This is why I prefer a steel pan.Replacing the gasket sometimes won't help. You need to either apply a good bead of rtv sealer or replace the pan itself.
Old Aug 8, 2006 | 11:09 AM
SRTthis's Avatar
the moroso pan has a machined face for the gasket... no problems there...
its also bigger then the 4x4 pan...
Old Aug 8, 2006 | 12:42 PM
pitstain's Avatar
get the moroso pan ..it DOES NOT site below the crossmember
Old Aug 8, 2006 | 12:43 PM
In my case is the flange on the Jasper transmission that's warped not the pan itself. The AL pan didn't leak a drop for the first 2 transmissions they sent me. Now that I finally have a transmission that actually works after two failures I'm not sending it back just for a pan leak. I probably just RTV the seal the next time I pull the pan off.
