OEM Brake pads
OEM Brake pads
I need to get a set of OEM brake pads and don't want to get raked at my local dealer, has anyone bought them online and from whom? Also I don't have part numbers for either set that would also help. Thanks, T
I guess they don't have to be OEM, here's the thing I have 25K on the original pads with zero issues, I going to upgrade to Todd's brake kit in the fall but I really don't want to drive/race on brake pads on that really need to be changed, I'm not doing cerimacs, I'll deal with the dust over melting rotors, maybe Hawks HPS would be a good upgrade and still be economical?
Hi Todd
Todd I used Performance Friction Carbon metalic brack pads from Auto Zone there about $52 each for the front and the rear work great Till you get your Big brake kit.
Just got back from Racing at Mont- Tremblant Canada 2.65 mile roadcoarse WOW was a BLAST!!!!
Chuck
Just got back from Racing at Mont- Tremblant Canada 2.65 mile roadcoarse WOW was a BLAST!!!!Chuck
Here you go Todd
Fronts
PFC brake pads at AZ part# 0702.20 reg. $54.99 OR 0702.10 for Z rated $75.99
Rears
Part # 0711.2 $54.99
I have had great luck with these and sware by them. I ran the Z's in the front they dusted a little more then stock but stopped alot better. I still have the rears in and they are hold up great.
Chuck
Fronts
Rears
Chuck
Originally Posted by Tazaster
Here you go Todd
Fronts
PFC brake pads at AZ part# 679.2 reg. $54.99 OR 679Z for Z rated $75.99
Chuck
Fronts
Chuck
crack
I was in need of some new brake pads, so I did a search and came apon this thread.
I went to Autozone to get a set of new front pads. They pulled out a set of 697.2 and as soon as I saw them I knew they were not the right ones. So we looked it up in the computer and they showed a set for a 8 lug application. PFC Part# 0702.02 I took at look at them, and said those looky like the right ones.
So I brought those home, and they were the right ones for the front of my Lightning.
So by my experience you need part number 0702.02 for the front of our trucks.
which TCE kit are you getting?
I just finished installing the 16 inch 6piston setup from Todd tuesday..
I was getting sick of only having the rears on.....15 inch 4 piston
Yes I know I have issues......
