Helppp!!!!!
Helppp!!!!!
not a huge problem, but a problem none the less.
I have this oil seperator http://www.svt-enthusiast.com/albums..._seperator.jpg
and 2 brass 3/8" air compressor fittings on each side. so i pull the rubber/foam off around the hose running into the upper intake and i find this small hose that connects to the much wider one right before the intake. How am i supposed to go about installing this??
any pics would help also. Thanks
-Sean
-Sean
Like this
Pull the Hose OUT OF the end piece (pull the plastic out of the Rubber)
Once you do that, push the Rubber piece on the Brass Barb Fitting and that takes care of that side.
Now take the original Plastic Line (you pulled out of the Rubber Piece) and use a small piece of Rubber hose to splice that back in the other side of the Seperator and that Brass Barb Fitting
