Removing water pump?
It'll come out... I "LIGHTLY" tapped on it with a hammer and it came loose.
Then it got donated for experimentation to a local engineer... WYDOPNTHRTL, the Water pump GURU!
Not to hijack the thread but which water pump is definitively considered "the best" now? I know there was debate about the Cobra R pump causing a slight hp loss. Then there's the Meziere, and I think the 03 04 Lightning water pumps were different from the early years? What is the de facto standard for consistent cooling and maybe freeing up some hp?
Although there have been reports to the contrary, any HP gains from a water pump -- even an electric one -- will likely be minimal. According to Rich, one of the guys who develops modular pumps, the Navigator pump (same as 03-04 Lightning but without the fan) has the best combination of flow and drive HP losses.
"Cobra" v. Navi:
The 2004 Navigator water pump is part #3L3Z8501CA. $116 from fordpartsonline.
"Cobra" v. Navi:
"Cobra" v. Navi:
"Cobra" v. Navi:
Originally Posted by pitstain
I will agree with Tim on that one.....also i think the Navi pump is cast from alluminum so the weight loss will compensate for your subway sandwich
Originally Posted by QKSILVR
I will assume this will work on a 99-00?
Rock Auto sells them foR $96
I bought it for $86 from Tousley Ford in Minnesota.
