Carparts.com
Old Jul 7, 2000 | 02:55 PM
Nathan's Avatar
Post Carparts.com
Carparts.com is a pretty decent site and if you have a copy of one of the major automotive rags, there is a coupon for 1/3 off. (coupon code 1863007) That makes it cheaper than the online store for similar parts. I got a set of bulbs for both my foglamps and headlamps there. Only problem is, they didnt come with instructions. Wyldman, I know you did a replacement on the fogs and lamps. Can you post some instructions?
[This message has been edited by Nathan (edited 07-07-2000).]
Old Jul 7, 2000 | 05:39 PM
thepawn's Avatar
Post
The headlamp replacement instructions are in your manual. Open the hood, there are two "tabs" sticking up on the left and right side of each headlight, push them slightly back as you pull up and they will "unclip". Then just pull the headlight out gently...unscrew the light ring and there you go! Just reverse the directions to put it back in.
For the fog lamps, there is a small tab above the center of the fog lamp, push that tab up and the fog light will come lose (i used a flathead screwdriver to push it up)... pull back the rubber boot and you'll see the light, squeeze the spring together and it will come out. Put your new light in, replace the spring & boot, and then just push the foglight back into place until you here the tab "click".
Daniel
[This message has been edited by thepawn (edited 07-07-2000).]
