True or False Oil fill tube filter style breather requires the PCM to be reprogrammed
Old Jul 28, 2006 | 12:35 AM
xnewyorker's Avatar
Question True or False Oil fill tube filter style breather requires the PCM to be reprogrammed
Read this on another site, looking for a true answer also......
As the title says.
I cannot find a single bit of truth no matter where I look.
I wanna add a fliter breather to my fill tube but some say you gotta reprogram the vehicle where as others say you dont.
Which is it???
Old Jul 28, 2006 | 07:10 AM
Rob_02Lightning's Avatar
Ask more than 1 person and you'll get more than one answer
The Theory:
With an open Breather you can take in un-metered air.
That is true.
The gray area:
How much frigging air ???
and
How much adjustment is needed ???
Hence some tuners do nothing, others believe adjustments are needed.
My Vote
NO CHANGE NEEDED!!
Most will agree but always say, for those running on the edge it could.......
Old Jul 28, 2006 | 08:22 AM
smokingozzy's Avatar
I vote no change needed! Jim
Old Jul 28, 2006 | 08:27 AM
Flash2211's Avatar
I was told, (by a tuner), that unmetered air will enter....didn't want to take the chance....do you???
Old Jul 28, 2006 | 08:43 AM
Bird's Avatar
If you install breathers on both valve covers and plug the entry points where the tubes used to go into the intakes (upper intake and intake tube before the TB), you'll not be allowing any 'unmetered' air into the intake system and a retune wouldn't be necessary.
Bird
Old Jul 29, 2006 | 04:08 PM
Don's Bolt's Avatar
It might make the check engine light come on. Some trucks can get awat without reprograming, but others need to have it reprogramed so the light won't come on.
Even if the light comes on, it won't hurt anything.
